Check Engin Lite - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 08-13-2008, 04:34 PM   #1
check engin lite
I have a dodge grand caravan 03.I did not tighten the gas cap so the check engin lite came on.How do I get it off?
jamesw6777 is offline   Reply With Quote
Old 08-13-2008, 07:47 PM   #2
electrical contractor
Rewards Points: 150
Disconnect the battery for about 5 minutes then hook it back up and light should be off.
Jimmy
Life is tough, Life is tougher when you are stupid.
wire_twister is offline   Reply With Quote
Old 08-14-2008, 07:55 AM   #3
47_47's Avatar
Rewards Points: 74
The check engine lite can be turned off by using a scan tool and clearing the codes. The lite will go out by itself after the ECM passes the EVAP system on three consecutive tests, however the code will be stored in the ECM memory for approx 250 test cycles, then erased from the memory.
47_47 is online now   Reply With Quote
Sewage Lid + check valve majorchamp Plumbing 2 07-07-2008 10:06 AM
Check Engine light Code P0430 Ford Explorer Mr Chips Automotive Repairs 4 04-09-2008 11:02 AM
Question about sump pumps and check valves lennyseleven Plumbing 3 11-08-2007 10:33 AM
