-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   check engin lite (http://www.diychatroom.com/f46/check-engin-lite-25160/)
jamesw6777 08-13-2008 04:34 PM
check engin lite
I have a dodge grand caravan 03.I did not tighten the gas cap so the check engin lite came on.How do I get it off?
wire_twister 08-13-2008 07:47 PM
Disconnect the battery for about 5 minutes then hook it back up and light should be off.
47_47 08-14-2008 07:55 AM
The check engine lite can be turned off by using a scan tool and clearing the codes. The lite will go out by itself after the ECM passes the EVAP system on three consecutive tests, however the code will be stored in the ECM memory for approx 250 test cycles, then erased from the memory.
