Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 04-03-2007, 01:31 AM   #1
changed bearing, now abs acting up
I have a 98 Blazer. The wheel bearing was going bad so I changed the whole hub/bearing assembly. It of course included a new ABS sensor. When I went for the test drive and braked normally-hard, the ABS activated and scared the heck out of me. I could get it to come on multiple times.
I'll double check the connections, they seem ok... it doesn't come on ALL the time, which I would suppose would happen with a loose connection.
I suppose a different manufacturer may have a different sensor? They look identical....
elementx440 is offline   Reply With Quote
Old 04-28-2007, 08:14 AM   #2
Extreme DIY'r Adk's, NY
Yes on a blazer the cartidge type bearing and abs sensor are one piece but if the sensor is dirty, got grease, oil or a fingerprint on it or smacked with a hammer or vibration it can be "out of calibration." Also if you pushed olf fluid back through the system to reinstall the caliper and pads this can cause all kinds of abs problems. Always crack the bleeder and let the fluid out in lieu of this on abs cars.
crecore is offline   Reply With Quote
Old 07-02-2007, 06:48 PM   #3
weekend warrior
johnny331 is offline   Reply With Quote
Old 07-02-2007, 07:40 PM   #4
redline is offline   Reply With Quote
Roof Sag/No Load Bearing Interior walls mrkleyn Roofing 1 08-13-2007 11:00 PM
Load Bearing Wall or not?? dtmbizzle Building & Construction 3 07-16-2007 08:12 AM
% total roof load on interior bearing wall? Grommet Building & Construction 1 03-29-2007 08:37 AM
moving another load bearing nailfun Carpentry 2 02-20-2007 09:10 AM
Taking out a portion of a bearing wall... mailsmc Remodeling 3 05-04-2006 01:21 PM
