Ceramic Pads From EBay Vs Autozone Or Other Store - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 07-27-2013, 07:51 PM   #1
Ceramic pads from eBay vs autozone or other store
I have a 04 Hyundai Santa fe 3.5 I was curious if getting ceramic pads from eBay vs autozone although autozone now is scrutinizing them more on return for defect not so much on replacement when It came time to another brake jobfor their free replacement. Autozone wants 35.99, eBay ranges 18.99 to 27.99 it doesn't appear to have hardware for either.
Ebay...Complete Set of Front and Rear Premium Brake Pads with Lifetime Warranty (Fits: 2004 Hyundai Santa Fe) 27.70
Is it worth buying online or just from your local store? I won't have this car another 3yrs at most.
NEW PREMIUM COMPLETE SET OF FRONT CERAMIC DISC BRAKE PADS WITH SHIMS (Fits: 2004 Hyundai Santa Fe) 18.99
GRed is offline   Reply With Quote
Old 07-27-2013, 07:57 PM   #2
Rewards Points: 254
If you don't mind brake noise. Most cheap pads you will get some squeaking.
cjm94 is offline   Reply With Quote
Old 07-27-2013, 08:19 PM   #3
Cjm94' explain...are you saying both are cheap...keep in mind I'm not keeping this car at most 2-3 yrs
Old 07-27-2013, 08:40 PM   #4
Rewards Points: 254
Cheaper pads are made of lower quality materials and tend to make noise. A quality set of pads are usually around $50-60. Not saying you are guaranteed to get noise, but its why our shop will not use cheap pads we are tired of complaints of noise
Old 07-27-2013, 08:46 PM   #5
I totally hear what your saying but...what about you buy what you can afford and within reason.being it will be history in 2 yrs or so..maybe sooner. If I had a high end vehicle I would put down 50-60 or more on a set. But for this car I'm trying to get an answer if its worth buying online vs the local stores
Old 07-27-2013, 08:52 PM   #6
Rewards Points: 254
Buy the best you can afford. They are your brakes not an area you want to get too cheap with.
Old 07-27-2013, 09:13 PM   #7
That I totally agree !!!!!!question.....should the hardware be replaced"
Old 07-27-2013, 09:18 PM   #8
Rewards Points: 254
Should but if not too rusted can be cleaned up and put caliper grease and all moving parts.
Old 07-27-2013, 09:26 PM   #9
Cool...I appreciate your time I haven't purchased them yet but will look for the rust. Another question.... I seem on youtube that there is 2 Phillip screws on each rotor that require a punch of some kind ????
Old 07-27-2013, 09:31 PM   #10
I do greese up all parts that should be...
Old 07-27-2013, 09:32 PM   #11
Rewards Points: 254
Yes they seize in there you may need an impact driver. It's a tool you hit with a hammer to break the screws loose. You may end up having to drill the head of the screw off to remove the rotor. They aren't required to use not all aftermarket rotors will even have the holes to screw them back in place.
Old 07-27-2013, 09:44 PM   #12
Ok soo most likely they will be either seized or frozen or rusted and if so I will drill the head off and not worry about them. I did read about them. So just the head needs to drilled off and the screw left.
Old 07-27-2013, 09:47 PM   #13
Rewards Points: 254
Yea you will need to grind them flush with the hub
Could use some help on ceramic vs duraceramic tile helpmike Flooring 17 03-29-2011 10:42 PM
Ceramic tile PEI rating - is this store manager trying to scam me? megs1082 Flooring 9 03-20-2011 05:03 PM
Pool Care Guide scottiedog Landscaping & Lawn Care 16 06-07-2008 08:41 PM
