Catalytic Replacement - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 08-04-2011, 01:55 PM   #1
Catalytic replacement
Does anyone know if the walker 16137 catalytic converter requires welding for a buick park avenue ultra? Its a slip fit on one end and bolt on for the other end. Does it require any modification? If so, what?
Duffnutz is offline   Reply With Quote
Old 08-04-2011, 08:22 PM   #2
Rewards Points: 252
The best thing to do is crawl under the car and look at the cat that is there. If it has the same setup, take some measurements for length. To get the old one off, use a hack saw or dremel, cut the U clamp, then cut along the pipe. You should be able to then use a pry tool (screwdriver) or air chisel to get it off.
Marty1Mc is offline   Reply With Quote
Changing Size of Replacement Window joside Remodeling 10 05-30-2012 04:46 PM
Wood Sash to Vinyl Replacement Windows Pittsville Building & Construction 3 05-27-2011 02:24 AM
window sash replacement kits? jimhome Remodeling 5 11-02-2009 12:48 PM
Replacement Window - Nail Fin Question smoenra General DIY Discussions 12 09-04-2008 10:19 AM
sill replacement or? watchtower7 Building & Construction 5 06-07-2008 03:50 PM
