Case Cx130 Hydraulic Problem - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 03-03-2010, 10:24 PM   #1
Case cx130 hydraulic problem
Hi,
I recently purchased a used 2006 Case cx130 excavator and for the last few weeks I notice that after about 30 minutes work the hydraulic system shuts down and nothing works. If I idle down for like 10 seconds then resume work rpm's everything works again. It seems to happen more as the machine warms up and I am using more hydraulic controls. I can feel the hydraulics chatter just before it cuts out. I have adjusted and then bypassed the hydraulic safety switch while troubleshooting and the problem still occurs so I do not think it is the safety switch itself. Anyone have any Ideas?
Sculptedurns
sculptedurns is offline   Reply With Quote
Old 03-04-2010, 07:56 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 328
Ayuh,... Have you changed the Filters,..?? Is the oil level up where it's supposed to be,..??
Bondo is online now   Reply With Quote
Old 03-04-2010, 12:10 PM   #3
I have dealt with this type problem before and it sounds like fluid starvation.
This can be caused by several things, already mentioned, and also check for kinked or crushed inlet supply.
I might mention that years ago, I owned a Case Backhoe and it did as you described. I did everything I could think of and finally found the problem. It had a "loose" piece of metal in the hyd. tank and as it moved around would eventually cover the inlet hole almost entirely.
It just takes a lot of common sense and a little luck.
Check the simple things first.
Giles is offline   Reply With Quote
Old 03-05-2010, 04:00 AM   #4
Thank-you
Thank-you for the good suggestions. I will follow up and check all the filters and see if any of the hoses are bashed in from the bottom or kinked. I already checked the oil level and changed most of the filters but not all. Their is one filter associated with the hydraulic accumulator that I did not change because I don't know if their is a special procedure to relieve the accumulator pressure or whatever before I open the system.
Sculptedurns
Old 03-05-2010, 02:30 PM   #5
Household Handyman
Rewards Points: 1,408
Some, but not all, hydraulic systems have a metal mesh filter (actually a fine strainer) within the tank. I've seen these clogged up just enough to do exactly what your system is doing. Check for a "filter" within the tank, it may/may not be there. Good Luck, David
Old 09-17-2010, 01:29 PM   #6
Builder,Plant.
Send a message via Skype™ to uggoon
Hi Everyone, just joined. A case cx 130 gets a bit lazy on the hydraulics when hot. It has a KPS pump but which type.Its a 2004 machine. Regards Pat
uggoon is offline   Reply With Quote
Tags
case , excavator , heavy equipment , hydraulic
75 year chimney leak problem mstanleyg Building & Construction 10 03-30-2010 01:38 PM
booster pump/ water pressure problem harpua103 Plumbing 3 12-30-2009 04:26 PM
flame sensor problem junkcollector HVAC 1 12-09-2009 09:19 AM
Grout peeling out from shower floor tiles. What's the problem? hellstorm Flooring 6 10-21-2009 10:15 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 07:26 PM
