Caravan Refit, Any Tips? - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 01-24-2009, 09:13 PM   #1
Caravan refit, Any tips?
Hi, We thinking about buying a caravan shell and fitting it out ourselves.
We are going to insulate with the best stuff we can find at the local hardware.
And other than keeping beds and storage lightweight and firmly anchored has anyone done this before and are there any tips/warnings? Mel
MellyB is offline   Reply With Quote
Old 01-24-2009, 10:02 PM   #2
Rewards Points: 264
Lots of good info on the net for this. Try expedition portal and
Not exactly fitting out a van, but a good start.
7echo is offline   Reply With Quote
Old 01-25-2009, 10:36 AM   #3
I haven't done a caravan but I have retro fitted a truck base panel van(7.5 tonne).
I used rigid foam wall insulation , glued it to the outside fiberglass walls, roof and floor sealed all spaces and cracks with expanded foam. and overlaid inside with marine grade plywood.
Installed double pane windows into the walls, vents through the roof , installed a furness, water heater and fridge. Plumber all water pipes in poly, mounted tanks underneath floor.
Installed electrical system and transfer panel for generator. It took quite a while but looked good in the end.
As I had quite a large payload I did not use anything flimsy. you might have more weight constraints.
asgard is offline   Reply With Quote
Tips for HEAVY sink install Sarah24 Plumbing 3 12-04-2008 07:01 PM
Sanding Tips?????? Dhankins Flooring 3 09-28-2008 11:57 PM
Knock down application tips needed gmhut Painting 1 07-31-2008 09:30 PM
Help :( Looking for tips on fishing PEX between floor joists .. drh HVAC 5 05-29-2008 09:26 AM
Need tips for installing/painting moulding BradG Painting 3 02-04-2008 12:44 AM
