-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   Caravan refit, Any tips? (http://www.diychatroom.com/f46/caravan-refit-any-tips-36754/)
MellyB 01-24-2009 10:13 PM
Hi, We thinking about buying a caravan shell and fitting it out ourselves.
We are going to insulate with the best stuff we can find at the local hardware.
And other than keeping beds and storage lightweight and firmly anchored has anyone done this before and are there any tips/warnings? Mel
7echo 01-24-2009 11:02 PM
Lots of good info on the net for this. Try expedition portal and www.fiberglassrv.com
Not exactly fitting out a van, but a good start.
asgard 01-25-2009 11:36 AM
I haven't done a caravan but I have retro fitted a truck base panel van(7.5 tonne).
I used rigid foam wall insulation , glued it to the outside fiberglass walls, roof and floor sealed all spaces and cracks with expanded foam. and overlaid inside with marine grade plywood.
Installed double pane windows into the walls, vents through the roof , installed a furness, water heater and fridge. Plumber all water pipes in poly, mounted tanks underneath floor.
Installed electrical system and transfer panel for generator. It took quite a while but looked good in the end.
As I had quite a large payload I did not use anything flimsy. you might have more weight constraints.
