Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Closed Thread
Old 02-16-2010, 01:54 PM   #1
Car trouble
My 1998 Olds Bravada is producing lukewarm/cool air through its air vents, and the air doesn't get hot. What things should I check in order to determine the problem, and what is the most probable culprit?
Justaguy
Justaguy is offline
Old 02-16-2010, 04:04 PM   #2
Car trouble
When was the last time the coolant was flushed and replaced? Could be a clog in the hose to the heater box. Is the fan blowing the same as it did before? If the adjustment to the heat is mechanical, it could have come loose. If it's a vacumm adjustment, one of the tubes could be disconnected or clogged. Has anyone worked on the car recently?
Ron
Ron6519 is offline
Old 02-16-2010, 08:40 PM   #3
Safe, Most of the Time!!
brokenknee's Avatar
Car trouble
Make sure you are not low on coolant.
"Clarity to Agreement" Dennis Prager
Picture/Photo Pitcher/Carafe ------- Where/Someplace Were/Be
brokenknee is offline
Old 02-16-2010, 09:46 PM   #4
Car trouble
I've had similar issues when there was a clogged heater core.
After you check all the easy stuff,
Locate the coolant lines heading through the firewall to the heat exchanger under the dash. Disconnect both in/out lines from the motor if you can or install T-fittings (you can get them in the prestone flush kit for $3.00)
hook a garden hose upto one, a drainage hose into a bucket on the other. Flush until a big snot shoots out and until the water runs clear. Do the same in the other direction.
Flush the rest of your coolant, refill will fullstrength + DISTILLED water.
Worked for me.
johnnyboy is offline
Old 02-17-2010, 02:42 AM   #5
Car trouble
The temperature gauge for the engine should be about in the middle of the range when the engine is warm. If it is indicating cooler, then replace the engine coolant thermostat.
Also there can be multiple problems. The temperature gauge for the engine can also be reading wrong. The cause of this is usually the "temperature sender". (NOT the engine coolant temperature "sensor" which is for the engine computer!) Then when you fix this, you might then see the temperature is too cool, then realize you also need a thermostat.
And there can be a third problem. The radiator may be clogged and the engine was overheating in the summer, so someone removed the thermostat to get it to cool better! For this new radiator and reinstall thermostat.
The engine thermostat should keep the water circulating hot. Even better is to use a factory service manual along with a thermometer and measure the temperature of the water. Should be what it says in the vehicle factory service manual set.
Anyway once you are sure the water is hot, then also the above about the water being able to circulate through the heater core can be a problem. (As they said above.)
And then there can be a problem with the little "door" in the HVAC system which switches from hot to cold (blend door). If you have an electronic HVAC system, do the following...
Try a "reboot"!
Remove a battery terminal for 10 minutes, then reconnect.
Turn ignition switch to on, but don't start.
Wait 1 minute.
DO NOT touch any buttons in the vehicle during this minute.
Then start vehicle and let idle for 5 minutes.
Drive above 45 mph as soon as possible.
This "reboots" all the computers in the vehicle including the A/C which then "resynchronizes" the actuator doors during the power-up.
This also reboots the engine computer and the idle and driving above 45 mph helps it to "regain" its operating memory.
If this does not work, you would need a GM Factory Service Manual set which would have complete troubleshooting instructions for this problem as well as complete part replacement procedures. Order from helminc.com or a GM dealer.
You would also need to know how to use a multimeter along with the instructions in the manual. How to use a multimeter...
http://www.google.com/search?hl=en&s...imeter&aqi=g10
Billy_Bob is offline
Old 02-18-2010, 03:54 AM   #6
Car trouble
not being funny m8
but what have you actually checked/done?
you cant ask a question like that without some kind of info?
have you had a look under the bonnet if so what at?
cmon help us to help you
Justaguy
jaye944 is offline
Old 04-14-2010, 01:17 PM   #7
cowboy dan's Avatar
Car trouble
i have seen alot of that on alot of cars. one i might check is that the blend door on your heating box is working. some are mechanical and some are electronic. ford and gm do that alot
cowboy dan is offline
Old 11-06-2010, 05:43 PM   #8
Car trouble
Three things,
Enviromental controls not working properly
Heater core is partially plugged
Antifreeze level is LOW..warning sign is low heat or no heat comming out of vents.
lorel is offline
Old 11-08-2010, 10:14 PM   #9
DIY'er
Car trouble
It could be a stuck open thermostat. I had this happen on my truck took forever to warm up and when it did the temp was really low and not much heat. If you haven't done it anytime soon, thermostat are cheap, change it out you should do it once a year at least. Mine the reason it stuck open was it got hung up on the side and it kept it open.
dirtrider73068 is offline
Old 11-08-2010, 11:13 PM   #10
Xtreme DIY'r
Car trouble
Hopefully almost 9 months later its fixed
Scuba_Dave is offline
Closed Thread
Just enough knowledge to get into trouble captain25 Introductions 1 03-23-2009 02:30 PM
Heil Gas Furnace has trouble starting sometimes dmanmtl HVAC 3 01-23-2009 06:36 PM
led trouble light TAKE PRIDE I.Y.W Electrical 8 12-07-2008 11:36 AM
P0420 trouble code Bad gas milage Help!!! lemoncoke Automotive Repairs 3 10-05-2008 09:50 AM
Arc Fault Trouble Shooting michael byrnes Electrical 4 06-13-2007 05:24 PM
