Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 06-25-2009, 08:54 PM   #1
car stalls when I put on brakes
What would cause a 2000 buick regal with a 3800 engine to stall when I put on the brakes.? It doesn't happen all the time.
jerry1967 is offline   Reply With Quote
Old 06-26-2009, 07:58 AM   #2
47_47's Avatar
Does it restart right away? When you put it back in gear does it stall? If it does I think the TCC (torque converter lock-up) solenoid is sticking on.
What we've got here is... failure to communicate. Some men you just can't reach. So you get what we had here last week, which is the way he wants it... well, he gets it.
47_47 is offline   Reply With Quote
Old 06-30-2009, 08:52 AM   #3
Now I can't get it to start at all. When I put my foot on the brakes all the dash lights come on but the car will not turn over. I checked the battery and alternator and both are good. I am thinking ignition switch. Does any body know how to change one?
Old 06-30-2009, 09:29 AM   #4
47_47's Avatar
If you put your foot on the brakes and the dash lights come on, first check your directional bulbs. You may have put in the wrong one.
First check for power at the starter. Use a test light and check between the big battery cable and an engine ground. This should be light all the time. Now check the small wire on the 'S' terminal of the solenoid. It should light with a helper trying to start the car. If both are light, you've got a bad starter/solenoid.
If you do not get the light at the S terminal during crank, you should get a wiring diagram. You could have a bad ignition switch, neutral safety switch, open fusible link....
Test first
Old 08-11-2009, 09:13 AM   #5
macro01's Avatar
i think you have a short circuit on the car
macro01 is offline   Reply With Quote
Old 08-11-2009, 07:37 PM   #6
Household Handyman
Jerry, unless you are a competent auto mechanic, either find one and make quick, good friends with him soon or take your car to one soon. Your 2000 Buick Regal has the GM OBD II series diagnostic center built into it. Only with the proper diagnostic equipment can you find the fault code which caused the stalling problem in the first place. It's very possible that the OBD II, combined with the ECM has shut down your engine to prevent any other possible damages. Good Luck, David
brakes teepee Automotive Repairs 7 02-22-2009 02:20 PM
Brakes Are Binding sweaty Automotive Repairs 6 01-15-2009 05:57 PM
Trailer brakes bucksone Automotive Repairs 1 09-01-2007 08:47 PM
Replacing Disc Brakes On 91 Toyota Corolla bobo Automotive Repairs 4 07-03-2007 07:31 AM
