Car Repair - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 03-19-2012, 01:07 AM   #1
Car repair
I have a chevy s-10 1995 thats losing acceleration
WASH is offline   Reply With Quote
Old 03-19-2012, 06:22 AM   #2
Rewards Points: 274
With all that detail that you have given, it could be anything from a bad piston to not pushing the gas enough going up a hill.
polarzak is offline   Reply With Quote
Old 03-19-2012, 09:02 AM   #3
Rewards Points: 52
I'm going with the gas pedal thing. If not that, the ball and chain hooked to the back bumper.
The Following User Says Thank You to DexterII For This Useful Post:
dougp23 (04-05-2012)
Old 03-19-2012, 11:13 AM   #4
Chevy
No its not the gas pedal
Old 03-19-2012, 11:18 AM   #5
Rewards Points: 13,296
Needs a tune up, dirty fuel or air filter, plugged up catilitic converter. All simple DIY things to do.
Since you did not list anything you have tryed were all going to have to guess.
Old 03-19-2012, 02:04 PM   #6
Rewards Points: 52
That's good. Now we're getting somewhere!
Old 03-19-2012, 02:32 PM   #7
i cleaned the cat-converter and it was driving good i was about to change the filter that is on the gas line. it has a new fuel pump and air filter
Old 03-19-2012, 02:34 PM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 192
Low air in the tires and wheel bearing seizing up, oh and get your foot off the break peddle while driving.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is offline   Reply With Quote
Old 04-05-2012, 07:13 AM   #9
bbo
too little info.
would also need engine size. specific symptoms about when/how much/what type of accelleration is applied. the more info you can supply, the better.
have you tried s10forums.com ? They can be rude, but are about the biggest one out there if I recall.
bbo is offline   Reply With Quote
Old 04-05-2012, 08:12 PM   #10
raylo32's Avatar
Rewards Points: 1,238
You "cleaned" the catalytic converter? Huh?? Maybe you contaminated it and killed which could cause major backpressure.
raylo32 is offline   Reply With Quote
Old 04-05-2012, 08:22 PM   #11
Rewards Points: 346
Agree. How does one CLEAN a catalytic converter? I had a 1985 S-10 that would do this, and I mean, I could go from 65 mph to no more than 20 mph, with it floored. Plugged catalytic converter in my case.
Pardon any typos, my IPad has a mind of it's own for spelling corrections!
dougp23 is offline   Reply With Quote
Old 04-15-2012, 11:47 PM   #12
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 1,884
+1
There is no "cleaning" of the catalytic converter that I have ever seen.
Old 04-19-2012, 08:05 PM   #13
Rewards Points: 1,062
I agree- as soon as we find out how to clean a cat, lemme know.........I still have my original one on my 87 sunbird, and Im sure its time to clean it.......
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 04-20-2012, 10:06 AM   #14
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 52
Have you changed your blinker fluid and rotated the air in your tires?
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 04-20-2012, 01:00 PM   #15
Now I have heard people say they have "cleaned them out" by gutting them, but never actually cleaned it out
D-rock is offline   Reply With Quote
Repair or Replace Garage Doors??? jbird0005 Windows and Doors 2 12-10-2011 07:42 AM
Repair 1962 Rheem pink toilet tank or find vintage replacement ? khaef Plumbing 0 09-09-2011 10:55 AM
Injected too much foam sealer to repair tub, how to remove foam? amodoko Plumbing 4 08-16-2011 01:42 PM
Choosing a Refrigerator based on Repair Value 1655graff Appliances 5 03-01-2011 09:49 AM
