Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 06-03-2012, 01:33 PM   #1
Car AC not blowing cold air
i checked under hood after no cold air blowing from vents.....i found 2 metal pipes going toward the fire wall, a small one with a cap and a larger one......the smaller pipe was cold and condensation was forming on the pipe, the larger pipe was warm,,,,from what i have read it should be the other way around.....what might cause this?
skepackers is offline   Reply With Quote
Old 06-03-2012, 03:54 PM   #2
biggles's Avatar
dryer is restricted... check out www.aircondition.com
Old 06-03-2012, 10:49 PM   #3
Definitely sounds like a restriction in the high side (small line). Have you had work done or an accident hit a small animal? A kink in the line will cause a psi drop also. If all looks good I would go with the dryer if its an expansion valve system. If its an orifice system. The dryer is in the low side line and shouldn't cause that issue.
cjm94 is offline   Reply With Quote
Old 06-23-2012, 12:48 AM   #4
AC is not something you can just guess at. Is the compressor running?? What are the pressures??Before you do anything, find this out. Would greatly help. Also, what kind of car is it??
msmith5554 is offline   Reply With Quote
Furnace Blowing Cold Air Only chilibean HVAC 4 04-05-2012 02:34 PM
Comfortmaker RPJ II blowing only cold air. lse HVAC 3 09-16-2011 07:14 PM
A/C not blowing cold air thill914 HVAC 11 07-27-2011 10:51 AM
cold air blowing from vent annyellin HVAC 0 12-19-2010 06:10 PM
Blowing cold air TODD_70 HVAC 1 11-24-2008 08:33 AM
