A/C Question - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 07-09-2014, 01:10 PM   #1
Rewards Points: 74
A/C Question
93 degrees temperature out and gauges say 30/190. According to Ford spec chart for ac, the low side is low and the high side is within range.
Thoughts about these numbers? A/C is cycling at 46 degrees and kicks back in at 56 degrees, then starts all over.
digitalplumber is just a name for use here, I am not a plumber!
digitalplumber is offline   Reply With Quote
Old 07-09-2014, 01:36 PM   #2
47_47's Avatar
Rewards Points: 58
Both pressures seem low, probably low on charge. Open all car windows, set a fan aiming at the condenser, max AC, blower on high. Increase and hold engine speed to about 2,000 RPM's. Let gauges stabilize and what are they?
There is a Ford tech on here, if he answers, listen to him.
47_47 is offline   Reply With Quote
The Following User Says Thank You to 47_47 For This Useful Post:
digitalplumber (07-09-2014)
Old 07-09-2014, 06:51 PM   #3
Rewards Points: 254
My guess would be a little low too. At that ambient temp high side should be in the low to mid 200's. Low side is usually low 40's. If it is cycling fast it is a good sign of low charge. It should have dye in from the factory if it is a newer car to help find leaks.
cjm94 is offline   Reply With Quote
Old 07-09-2014, 07:18 PM   #4
Rewards Points: 74
New truck, 2013 bought last November. Its not a rapid on off cycle like you get with a system that is known low, but cycles regularly (constantly) off at the low end at 44-46 degrees and back on when it hits 56 degrees.
Its under warranty so I guess I need to take in?
Old 07-09-2014, 07:37 PM   #5
Rewards Points: 254
Could be temp blend door actuator sticking. I have seen quite a few fail causing warm air when asking for cold. Not uncommon to cycle like that.
Another Aluminum Siding prep question aribert Painting 6 03-14-2013 01:48 PM
DRIcore question trailblazer1229 Flooring 0 02-24-2010 09:25 AM
3 Phase meter socket question a320200 Electrical 4 12-11-2009 12:45 AM
An unasked question is the only dumb question jackie treehorn Kitchen & Bath Remodeling 1 09-20-2009 08:24 PM
Basement Renovation Question KUIPORNG Remodeling 234 08-26-2008 08:19 AM
