A/C Not Working - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 08-07-2007, 09:08 AM   #1
Rewards Points: 790
A/C not working
Over the past few weeks I've noticed that my truck's a/c has slowly started to go out. Now, it does not cool at all. I have been told that it could be low freon, but I am not sure how to check for this. I also checked the resevior for the engine coolant and found it was empty. My truck is a 97 Dodge Dakota Sport, and it has never overheated, but it does sometimes die (I think because the idle is set too low). Any suggestions or other reasons why the a/c is not working?
cibula11 is offline   Reply With Quote
Old 08-09-2007, 12:50 AM   #2
you may have a leak in your lines
auto stores have kits that you can use to replace your a/c coolant.
dienam3less is offline   Reply With Quote
Old 08-09-2007, 10:00 AM   #3
Rewards Points: 790
The truck is 10 yrs old, so I'm guessing that it could just be that it is old and needs to be replaced. I find it weird to think that all of a sudden there is a leak. Are these kits pretty easy to use?
Old 08-09-2007, 12:35 PM   #4
my grandpas car is about 10 years old and he has a leak around his compresser. parts do wear out. as for the kits im not sure how hard they are to use... never used them only seen them. my grandpa took his car to the garage and they filled up his a/c and then a week later is wasnt working again so they did a check on the system n found it had a small hole. personaly i think u should have a garage check and make sure u dont have a leak. no point it in if there is a leak.
GE fridge evaporator fan change and still not working Trish Appliances 2 03-30-2008 01:47 PM
Halogen motion sensor light stopped working, Incandescent still works keyser soze Electrical 6 05-29-2007 08:53 PM
Help, new fixture not working Christine Electrical 3 01-17-2007 06:24 PM
three-way only working on one switch amydawn Electrical 11 07-11-2006 05:52 PM
Furnace stops working once a day - help Da_Bears HVAC 2 01-26-2006 01:19 PM
