A/C No Longer Working - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 07-02-2011, 06:01 PM   #1
Rewards Points: 87
A/C no longer working
After not being used all winter, I finally cranked up the AC in the car, and no cold air.
Im assuming it just needs to be recharged, but it was working perfectly fine last fall.
Just wondering if there is any little things to check. The pump sounds like its still running, and the fan belt is nice and tight, but other than that Im clueless.
Also, is it easy to recharge the A/C yourself? Ive seen recharge kits advertised before, but not sure if they are more gimmacky or not.
phantasm72 is offline   Reply With Quote
Old 07-02-2011, 08:42 PM   #2
Rewards Points: 252
When you turn on the AC, is the center of the compressor turning? There is a clutch that engages when the AC is engaged. That clutch will spin. If the center is not moving, then next check pressure. If the center is spinning, you still need to check the pressure to make sure you don't have a blockage. But, most likely, it will be simply low on refrigerant.
What year is your car? If after 1995, it is probably R134A. You may be able to just put a quick charge on it. (R-12 requires a license to buy.) If it's R134A, you can get a refill kit from any auto parts store. Try to find the stuff with dye if possible. Also, make sure it has a pressure gauge on it. The system is filled at the LOW pressure side of the compressor. You can tell the low side by looking at the aluminum piping. The low pressure pipes are larger than the high pressure side. You will find a connector on one of them to allow you to fill the system.
However, you need to ensure you don't have a major leak. If the pressure is completely gone in the system, then you will need to fix the leak. Once the leak is fixed, it needs to be evacuated. That is sucking out the air (and moisture with it) and creating a near vacuum situation in the system. After that, it can be filled.
Good luck, post back if you have any questions.
Marty1Mc is offline   Reply With Quote
Old 07-03-2011, 05:12 PM   #3
Rewards Points: 87
The compressor does turn, but it goes on and off at about 4 or 5 second intervals. So from what you are saying, it sounds like the pressure is probably very low.
The car is 2001
You were mentioning stuff with a dye? Is that to help locate a leak if there is one?
Old 07-03-2011, 05:19 PM   #4
Rewards Points: 252
With the compressor fast cycling, then it's likely low on refrigerant. There is a low cut-off switch on the low pressure line that interrupts the clutch when the pressure drops too low (usually below 20 lbs of pressure). The dye will allow you to use a black light and see where it is leaking. The leak will show up as a bright yellow.
However, if you can still just use R134A and fill the system. You may find the leak is slow enough that this will work on a once a year basis.
Maytag IntelliDry pye/4500 Dryer not working 57_Hemi Electrical 2 11-19-2010 09:28 PM
goodman ck49-1b unit not working whyme123 HVAC 1 06-05-2010 11:31 AM
side by side light swithes not working katkell2645 Electrical 2 10-17-2008 07:22 PM
Two switch in one box: only one working jdtsmith Electrical 12 09-29-2008 01:32 PM
Furnace stops working once a day - help Da_Bears HVAC 2 01-26-2006 01:19 PM
