A/C Leak
My A/C needed more refrigerant this spring. Charged her up and all went well for about a month before it was blowing warm again. So I charged her again with one of those leak sealant. Same thing, about a month, now its starting to blow warm again.
Im guessing its a leak, small enough that itll hold a charge for a few weeks, but large enough that the leak sealers arent effective. Question now is how do I go about checking for leaks? and where is a good place to start? Just hoping its something you can do yourself without having to spend $150 at the shop to have it fixxed. Cheers |
cheers. have shop do it. you can start tossing money at it, buying dye etc, then you'll have to replace parts, which means - evacuate system and fully recharge anyway. might as well gid id done right from the get go.
Personally, I would throw a can of leak detector in it and if the leak is found, fix it, as I have an evacuation pump and the gauges for refilling. Unless you have a pump and gauges, you probably should do as ukrkoz says, and take it to a shop. Be prepared to pay more than $150 though.
If it is leaking that fast then you should be able to see some wet area along one of the pipe joints or on the condenser itself. replace leaking part then take to shop to have a/c system vacuum and charged. If blowing warm then not to much is left in the system, just remove leaking part slowly to keep from allowing anything left in it to spray on you. Good luck
when it's blowing warm is the AC turning on and off? you will hear it clicking on and off when the refrigerant is low. Answer this and then we can troubleshoot to the next step.
you won't see any wet area when it takes weeks to get warm again. I refilled 3 cars a few years back with the refrigerant without oil to lubricate and all 3 AC died by the next summer. have to get the free on with lubricant.
Put dye in, find leak. Don't worry about purging the system since it's leaking out anyway. When it runs warm again and the refrigerant is gone, replace the o-ring or whatever is leaking, and make sure you replace your dryer, it should be replaced every time the system is opened.
Now you have your leaks fixed, go to a shop, and pay 100 and tell them to pull vacuum and recharge by weight. They should charge you about 100. 30 bucks for dryer or so, and add cost of whatever is causing your leak, plus the 20 or so for the UV kit and dye. Worth it to DIY, not incredibly difficult. |
I just fixed an air conditioner in a Chrysler Concorde and it seemed like the free on had leaked out. the air was warm. but the compressor wasn't turning off and on. the compressor wouldn't eve. turn on. there is a transducer that senses the pressure and tells the compressor to turn on and off. don't spend money in die if the compressor isn't turning on.
the r134a with out lubricating oil will ruin ac parts.
right. the Concorde ac also worked and it also needed refrigerant and it also stopped blowing cold air 4 months later. it's the same scenario.
| All times are GMT -4. The time now is 03:30 AM. |
