Bypassing The Airconditioner Compressor - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 01-25-2012, 01:36 PM   #1
Rewards Points: 27
Bypassing the airconditioner compressor
I have a 2007 Ford Tauras and would like to know. Can I bypass the compressor. It is trying to lock down and for now I just need to bypass it because I can not afford to replace the compressor.
ROBBYT3 is offline   Reply With Quote
Old 01-25-2012, 01:42 PM   #2
Rewards Points: 254
That depends. Is it the pulley bearing that is locked up or the compressor itself? Does it work ok with the ac off, if so unplug the compressor so it can't engage. If it's the bearing for the pulley you are out of luck.
cjm94 is offline   Reply With Quote
Old 01-25-2012, 06:07 PM   #3
Household Handyman
Rewards Points: 1,408
Depending on the vehicle: You may be able to find a parts store in your area with an "old timer" who knows how to look up a shorter drive belt, either the older "V" style or the serpentine style, which would by-pass the A/C compressor. OR: For some cars they(Dorman more than likely) make an idler pulley kit which replaces the A/C compressor totally allowing you to use the original belt.
Old 01-25-2012, 08:32 PM   #4
If all else fails, maybe you could get a used A/C compressor at a wrecking yard for not too much. Then replace it and leave the wire disconnected.
Billy_Bob is offline   Reply With Quote
Old 01-25-2012, 10:01 PM   #5
ukrkoz's Avatar
Rewards Points: 978
on many cars, a/c is optional. you can simply buy a belt for no a/c version. it automatically bypasses a/c pulley. any knowledgeable parts store guy can find you a shorter belt, if needed.
ukrkoz is offline   Reply With Quote
Old 01-29-2012, 08:18 AM   #6
Rewards Points: 1,062
Good idea. I agree. Worst, buy a used one as mantioned above at car-part.com. You can scroll (no ac compressor pun!) down to the cheapest compressor and order that!
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
3 phase 230/460 air compressor install questions DinAZ Electrical 7 10-21-2011 10:28 PM
Help assembling compressor jfhspike Tools 5 03-27-2011 10:07 AM
Air compressor and framing nailer for DIY ADKstorm Tools 20 11-11-2010 07:38 AM
Please help: blown fuse, slow compressor fan, and hissing noise from compressor frazwr01 HVAC 10 06-27-2010 09:08 PM
New Compressor - Wrong Charge? shayneb HVAC 4 08-23-2008 08:13 AM
