Broken Bolt, Rod Still Stuck In There - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 10-29-2013, 08:58 PM   #1
Rewards Points: 12
Broken bolt, rod still stuck in there
hi all, bought a house, previous owner left a snow blower behind. Cleaned it up, changed the oil then I go put gas in it and voila I have a gallon of gas on my garage floor.
Looks like he broke the carburetor bowl bolt's head somehow and then duct taped it to keep the whole thing in place
Anyway, the bolt stud is still stuck in there, any ideas on how I can get it out of there. I am attaching a picture. I guess worse case I can buy a new carburetor. Already removed it so I can work on it.
Thanks for any and all advice!
Broken bolt, rod still stuck in there-20131029_181906.jpg   Broken bolt, rod still stuck in there-20131028_173948.jpg
oz1907 is offline   Reply With Quote
Old 10-29-2013, 09:12 PM   #2
Rewards Points: 12,882
How lucky you feeling?
There a pain to get out, the whole thing is hard to get a good enough grip on in a vice.
Your going to have to use a prick pinch to hit the exact center of that brass piece.
Once it's marked drill it out with the proper sized drill bit then use an EZ out. A good EZ out will have the size to drill right on it.
Going to have to be real easy and slow when drilling brass. It's going to want to grab and once it goes through stop ASAP because it's going to want to keep on going into the hole.
oz1907 (10-30-2013)
Old 10-29-2013, 10:14 PM   #3
Rewards Points: 392
Looks like someone already tried an easy out and broke it off. If that's the case, I'd start looking for another carb.
rustyjames is offline   Reply With Quote
The Following 2 Users Say Thank You to rustyjames For This Useful Post:
joecaption (10-29-2013), oz1907 (10-30-2013)
Old 10-29-2013, 11:27 PM   #4
Rewards Points: 6,652
I would just go and purchase a new carb, or convert to Propane. See http://runpropane.com/For_Small_Engines.php
The Following User Says Thank You to gregzoll For This Useful Post:
oz1907 (10-30-2013)
Old 10-29-2013, 11:49 PM   #5
I'd go carb shopping as well. Cleaning that up wouldn't be worth the effort.
Lotek is offline   Reply With Quote
The Following User Says Thank You to Lotek For This Useful Post:
oz1907 (10-30-2013)
Old 10-30-2013, 07:34 AM   #6
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 906
Once you snap the EZ-out...you are "screwed".
Pardon the pun.
The Following User Says Thank You to Windows on Wash For This Useful Post:
oz1907 (10-30-2013)
Old 10-30-2013, 10:21 AM   #7
Rewards Points: 12
Thanks!
Thank you all. New carb it is. I will take a look at the propane idea though, that sounds interesting.
Old 10-30-2013, 11:04 AM   #8
Rewards Points: 452
For GAWD sake and yours too get the dam thing outdoors to gas it.
SeniorSitizen is offline   Reply With Quote
Old 11-06-2013, 12:38 PM   #9
Mold!! Let's kill it!
Rewards Points: 2,012
A left hand drill bit would probably back it out pretty quickly.
Old 11-06-2013, 07:00 PM   #10
Rewards Points: 1,062
Dang, thats one good camera, oz.
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 11-07-2013, 12:59 PM   #11
Rewards Points: 12
Thanks again everyone. I was actually able to get it out. I filed down one of those eye glass screw drivers to make it very sharp, was able to drill a tiny entry point and hammer it in slowly and get the bolt out. $10 in parts, $8 in shipping =) ... so far so good.
Old 11-07-2013, 04:46 PM   #12
Rewards Points: 392
On some carbs like Tecumseh's that bolt also serves a jet, it'll have small holes drilled in it. If that's the case it'll have to be matched to the carb.
The Following User Says Thank You to rustyjames For This Useful Post:
oz1907 (11-07-2013)
Old 11-07-2013, 06:17 PM   #13
Rewards Points: 12
You are right James this was one of them found it online at http://www.upstateoutdoorpowerequipment.com/
Broken bolt emerging from cement Mallethead Concrete, Stone & Masonry 7 06-03-2013 03:37 PM
Broken off bolt gerardswork General DIY Discussions 20 05-28-2012 11:05 PM
toggle bolt stuck in stud pilcher Drywall & Plaster 1 06-28-2010 09:14 PM
Broken caliper bolt chrissyb Automotive Repairs 12 12-28-2009 04:18 PM
My dead bolt is broken kimigriffith General DIY Discussions 3 06-09-2008 01:02 AM
