Brakes Not Working - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 04-02-2012, 03:59 PM   #1
Question
Brakes not working
We have a 93 ford mustang lx. We recently put in a brand new master cylinder but the brakes still don't seem to be working. I thought maybe it was the power assist because when the engine is off, the brake pedal goes straight down to the floor. There doesn't seem to be a vacuum leak or a fuel leak either.
What else could it be? The booster maybe?
Thanks for your time!!!!
Marina6 is offline   Reply With Quote
Old 04-02-2012, 04:04 PM   #2
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Did you bleed the brakes?
There is air in the system some where,that causes the pedal to go to the floor.
The is a bleed screw on each caliper on the from and on the drums in the back.
Loosen one at a time and have someone step on the pedal slowly (do not pump the pedal) do that until fluid comes out of the screw.Once it does lock it back up and move to the next tire and repeat process. Have some brake fluid on hand to refill fluid to came out.
sublime2 is offline   Reply With Quote
Old 04-02-2012, 05:10 PM   #3
Mhmm
yes we've already done that and put new brake fluid in it. When we pump the brakes the fluid seems to only go up and down though. Thank you for your reply!
Old 04-02-2012, 06:25 PM   #4
Rewards Points: 254
Did you bench bleed the master before installing?
cjm94 is offline   Reply With Quote
Old 04-10-2012, 06:28 PM   #5
new lines maybe, they could be corroded inside or take all the calipers off and open them up and clean it inside out but do that before u buy new brake lines and hoses cuz u will waste alot of money if u buy all new lines and ur still having that problem
will8813 is offline   Reply With Quote
Old 04-10-2012, 06:45 PM   #6
http://www.autozone.com/autozone/par.../N-izpyuZ8kp1m
Tags
1993 , brakes , lx series , master cylinder , mustang
Receptacle stopped working lovetobuild Electrical 3 02-11-2011 11:05 AM
Some things not working on a circuit while others are? speedster1 Electrical 7 11-24-2010 07:23 AM
side by side light swithes not working katkell2645 Electrical 2 10-17-2008 08:22 PM
Two switch in one box: only one working jdtsmith Electrical 12 09-29-2008 02:32 PM
Furnace stops working once a day - help Da_Bears HVAC 2 01-26-2006 02:19 PM
