Brakes - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 03-13-2014, 07:16 PM   #1
Rewards Points: 164
Brakes
Have a 94 chevy k1500 just bought this re-did everything on it, now the brakes seem to have an issue, but don't know what it could be the brake cushion when first pushing on them, then goes right to the floor?? Pads are good all around, bled all the brakes, master cylinder working no leaks on any wheel. Cylinders I am stuck help???
bostonwindows30 is offline   Reply With Quote
Old 03-13-2014, 08:27 PM   #2
Ole Wood Worker
BigJim's Avatar
Rewards Points: 798
Sounds like you may not have gotten all the air out. Also on some master cylinders you have to bleed the brakes so the piston between the front and rear reservoir is centered.
Another thing it could be is the residual check valve could be bleeding back and not holding residual pressure in the system or the cup on the piston could be bad letting fluid to bypass instead of pressurizing. Could be trash doing the same thing also.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 03-13-2014, 09:57 PM   #3
ukrkoz's Avatar
Rewards Points: 992
Pedal goes down = bad master.
Or you have leak.
Yes, I read what you believe.
ukrkoz is offline   Reply With Quote
The Following User Says Thank You to ukrkoz For This Useful Post:
Bondo (03-14-2014)
Old 03-14-2014, 01:37 AM   #4
Rewards Points: 164
Ok sounds good guys, thank you I think I will change the master cylinder, and bleed the brakes and go from there??
Old 03-14-2014, 02:10 AM   #5
I had the same thing happy to a 91 Jimmy after putting on front pads.
It was a standard job loosened the bleeders..use my clamp to push the pistons in.
Put in the new pads ..put the calipers on..I am used to a couple pedal applications to get the pistons and pads up against the rotors.
Didnt happen.
What finally worked were real hard short jabs at the pedal..very fast jabs .
Cause..I dont know..but they worked fine once whatever happened fixed itself
Midwest Man is offline   Reply With Quote
Old 03-14-2014, 03:37 AM   #6
Rewards Points: 164
So your saying to drive it and hit the pedals fast and hard maybe it's stuck a little??
Old 03-14-2014, 07:13 AM   #7
Rewards Points: 1,300
I will agree with the bad master as well. Make sure you bench bleed it before installing it. Also, make sure your rear brakes are adjusted properly. I have seen this cause many a low brake pedal.
danpik is offline   Reply With Quote
The Following 3 Users Say Thank You to danpik For This Useful Post:
BigJim (03-14-2014), Bondo (03-14-2014), r0ckstarr (03-16-2014)
Old 03-14-2014, 09:49 AM   #8
No ...I did it while parked.
Old 03-14-2014, 09:08 PM   #9
ukrkoz's Avatar
Rewards Points: 992
OP, hard consecutive braking after fast acceleration is to bleed ABS module. I don't think you have one for 94.
Anyway. You do better off bench bleeding master.
But you do not have to replace it. Repair kits are readily available and it's very simple job.
BigJim (03-14-2014)
Old 03-15-2014, 04:25 AM   #10
Rewards Points: 164
I have noticed when braking that it pulls to the left, after driving it for a while it seems actually to get better???
Old 03-15-2014, 11:32 AM   #11
Rewards Points: 164
Could the calipers be stuck?? On one side??
Old 03-15-2014, 11:33 AM   #12
ukrkoz's Avatar
Rewards Points: 992
Pull to the side=sticky caliper or clogged line.
Shine flash light at rotors. Is any one of them blue-ish or brown-ish looking? Signs of over heating.
Old 03-15-2014, 11:40 AM   #13
Rewards Points: 164
Gotcha so sounds like I need to replace calipers
Old 03-15-2014, 12:05 PM   #14
If you have a sticky caliper..that side will overheat quickly.
I am more apt to think that your other side {wheel} is under braking.
Pads may have not seated yet or you have contamination or the rotor.
Binding is also a possibility...The caliper assembly needs to be able to float proper to pull the caliper..in other words the piston pushes the pad on one side then the caliper floats to apply the other pad.
Old 03-15-2014, 12:37 PM   #15
Exterior Construction
Windows on Wash's Avatar
Rewards Points: 5,568
Bleeding lines can be tricky some times. What did you change out in the system?
Does it have ABS?
Did you open the bleed screw prior to pushing the piston back in?
Burnishing or bedding in new brakes polarzak Automotive Repairs 4 10-25-2012 09:33 PM
Electric Trailer Brakes and Tires Condition Questions DIYguy2000 Automotive Repairs 10 09-18-2012 08:15 AM
New brakes pulsating shanecurran Automotive Repairs 17 07-06-2011 02:06 PM
Trailer Brakes NEED HELP plz Jeepster Automotive Repairs 4 09-13-2009 06:45 PM
Replacing Disc Brakes On 91 Toyota Corolla bobo Automotive Repairs 4 07-03-2007 06:31 AM
