Brakepads R And R - Automotive Repairs - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 08-22-2010, 10:38 AM   #16
Oldguy
Rehabber's Avatar
There is a lot of advise on this site that will 'get you by', but most people want to do it RIGHT. Part of brake maintenance is to flush the brake fluid every 2-3 years. Brake fluid is hygroscopic, and will absorb up to 6% water. It takes it right out of the air. What do you think that water does to the inside of your brake hydraulic components? The brake systems on modern cars are complex and expensive. Don't be pennywise and pound foolish_ flush that brake fluid.
If you think you can, or if you think you can't, you're probably right.
ASE certified master auto tech, Retired.
Rehabber is offline   Reply With Quote
The Following User Says Thank You to Rehabber For This Useful Post:
nap (08-22-2010)
Old 08-22-2010, 01:31 PM   #17
Rewards Points: 256
yes, but the brake fluid is not the problem right now , pedal going to floor sitting on driveway room temeperature. you have air in your lines. might have to re bleed the master. because even if your sytem was dirty and clogged it would still stop the brake pedal from going to floor .. right ?
oldrivers is offline   Reply With Quote
Old 08-22-2010, 02:24 PM   #18
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
if the rear calipers are also used for the parking brake, it could be they are not adjusted as well.
since the OP has posted only once, everything at this point is a guess. Need more info.
so,
air in the lines
park brake adjust
caliper not sliding properly
pad installed incorrectly (unlikely but I know of a few things that could have happened to cause this with improper installation)
damaged master cylinder (certain GM cars in particular are easily damaged when bleeding the brakes improperly)
ABS modulator needs to be cycled (some cars require this when bleeding the brakes)
I would suspect one of the first 2 as the likely culprit and without more info, that is the best I can guess.
Old 08-22-2010, 11:25 PM   #19
Pad replacement is always the best time for a flush. Hook a hose to the bleed screw,back it off, spread the caliper, tighten bleed screw, install pads. complete all four corners, clean out Master Reservoir, Fill with fresh brake fluid, pump up peddle, refill Master. Old school start bleeding furthest from the Master, using a Vacuum pump or a second person at the peddle. Check and fill master during and after each Caliper. If peddle pumps up there is air in the system, bleed each corner again after pumping up till all air is removed.
Sorry Guys I'm not ASE. But Federally licensed Airframe and Power Plant.
Tired is offline   Reply With Quote
Old 08-23-2010, 12:03 AM   #20
Originally Posted by marcello View Post
changed brake pads front and rear and bled all calipers, brake pedal goes all the way to the floor,why?
Did the pedal go to the floor before changing pads?
RDGreen is offline   Reply With Quote
Old 08-23-2010, 09:13 AM   #21
Do work
Rewards Points: 81
agree that changing you break fluid every 2 years is a good idea. I however usually get around it every 3 to 4 years.
Back to the OP's problem. I would re bleed the breaks again. Sounds like you just have some air in there.
liquidvw is offline   Reply With Quote
