Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 09-23-2011, 01:15 AM   #1
brake replacement problem
I have a 91 grand voyager and just replaced all front brake parts from rotor to calipers to pads.the passenger side caliper when put over pads easily and tightened (2bolts) sticks out at top and doesn't go in to lock as if the pads were too thick or rotor hub not deep enough.<Drivers side caliper. locks in place at bottom hook in and is secure.
Its like the outside edges of caliper are sticking out to far to hook in.
Any ideas as to what it may be.
brake replacement  problem-forumrunner_20110923_001327.jpg   brake replacement  problem-forumrunner_20110923_001440.jpg
hidden 1 is offline   Reply With Quote
Old 09-23-2011, 08:31 AM   #2
A Little Of Everything
New calipers... Is it possible that you need to further compress the caliper?
Probably too simplistic, but here's hoping!
DrHicks is offline   Reply With Quote
Old 09-23-2011, 07:51 PM   #3
I too have a voyager- did my brakes a few times. Sometimes you have to jiggle them a bit. Look at them from different angles and maybe you will notice something that needs to be gently pounded (oxymoron?) in.
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 09-23-2011, 09:47 PM   #4
ukrkoz's Avatar
I am assuming, right pic is Ok, and left one is "No good" with lock not engaging? Is it simply the way pics are taken, or is brake pad on the left, no good one, protruding up higher than the right, OK one?
ukrkoz is offline   Reply With Quote
Old 09-24-2011, 12:19 AM   #5
found out what it was....the edge that the caliper hooks was slightly broke off...just enough to not latch....got a caliper w that support part in it( crazy-only advanced includes that bracket w caliper!)
3 wasted days over 1/2 of an inch
Old 09-24-2011, 07:25 PM   #6
ukrkoz's Avatar
glad you got it. it's brakes.
Brake Pad replacement 2008 Sorento diamondgus Automotive Repairs 7 04-23-2010 10:05 PM
window sash replacement kits? jimhome Remodeling 5 11-02-2009 01:48 PM
Bradford White sacrificial anode replacement problem vinnie1 Plumbing 3 07-27-2009 09:01 PM
Stymied by window leakage problem. Matth3w General Discussion 5 06-11-2008 07:26 PM
Post-Tension Slab Problem Advice/Help Mike McBride Building & Construction 2 01-09-2007 02:51 PM
