Brake Problems - Automotive Repairs - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 07-14-2013, 06:28 AM   #16
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Originally Posted by Hardway View Post
"You have to bleed all 4, one at a time."
Really and how do you do this?
Really?
Are you able to comprehend what you read?
sublime2 is offline   Reply With Quote
Old 07-14-2013, 06:46 AM   #17
Take about 2’ of hose/tubing that fits snug on the wheel cylinder bleeder screw.
Zip tie the hose to a spring clothe pin, so you can clip the hose on the rim of a jar.
Make sure the hose is at the bottom of the jar, with just enough clean brake fluid to cover the end of the hose. (Either hang the jar or set it on something or use a longer hose.)
Now put the hose on the bleeder screw on the wheel furthest from the master cylinder. (you may need to put a little grease around the hose on the bleeder, not very often.)
Open the bleeder, you can either gravity bleed or push the peddle.
Make sure you keep the master cylinder full. (You should be able to bleed all four with less then a half quart of fulid.)
Watch the hose in the jar, for bubbles. Once there are no bubbles, close the bleeder and move to the next furthest wheel.
After you have bled all four wheel cylinders repeat and check for bubbles.
This is fool proof and my standard method.
Disclaimer.
I am not a Master Mechanic and this information is for discussion purpose only.
Hardway is offline   Reply With Quote
Old 07-14-2013, 06:50 AM   #18
[QUOTE=sublime2;1215608]Really?
Are you able to comprehend what you read?[/QUOT
Appreanly not this early in the morning.
The Following User Says Thank You to Hardway For This Useful Post:
sublime2 (07-14-2013)
Old 07-14-2013, 07:03 AM   #19
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,314
Thanks guys, a couple new ideas, gravity and cross bleeding. I'll let you know how I make out.
Although, now that I think about it, there is one more variable that may be a factor and that's my helper, who is my 90 yr old father. I ask him where the brake pedal was, thinking I'm going to get the answer up or down, and he said "next to the gas pedal." What can I say, he was correct.
I tear things down and build them up.
Clutchcargo is online now   Reply With Quote
The Following User Says Thank You to Clutchcargo For This Useful Post:
Old 07-16-2013, 03:20 PM   #20
Rewards Points: 87
Typically you bleed the corners in order of distance from the MC, starting with the furthest away, so on a LHD car: RR, LR, RF, LF. Speed bleeders are worth the money to me.
huesmann is offline   Reply With Quote
The Following 2 Users Say Thank You to huesmann For This Useful Post:
rustyjames (07-16-2013), Windows on Wash (07-23-2014)
Old 07-16-2013, 07:23 PM   #21
Bigplanz's Avatar
Rewards Points: 952
A service manual should detail the proper bleeding sequence. Try autozone's website. Lots of free manuals there.
Bigplanz is offline   Reply With Quote
Old 07-23-2014, 11:46 AM   #22
Rewards Points: 37
Sometimes it helps to tap on the cylinder to release trapped air. That should get you in the ballpark where you should start getting some pedal pressure to start the bleeding*,Worked in a brake and front end shop.
garykerr is offline   Reply With Quote
Hot water problems - not sure what's causing it ngk Plumbing 6 03-29-2013 07:42 PM
Pendant Lamp Electrical problems JeffDIY Electrical 1 10-11-2012 04:36 PM
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 02:51 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 04:51 PM
2005 Dodge brake wiring schematic dwallace Automotive Repairs 2 09-10-2007 08:48 AM
