Brake Problems - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 07-13-2013, 05:52 PM   #1
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,312
Brake problems
I've working on my fathers car. It's a run of the mill '96 Ford Taurus. One of the two brake lines running to the rear rusted out and he lost all of the brake fluid getting it home.
I decided to replace both of the rear brake lines because the other one looked pretty bad too.
Now I cannot seem to get the air out of the system. I'm up to 3 laps around the car with bleeding and it still has very spongy brakes. I must have gone through a half gallon of brake fluid.
Any ideas would be greatly appreciated.
thanks,
I tear things down and build them up.
Clutchcargo is offline   Reply With Quote
Old 07-13-2013, 05:59 PM   #2
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
You have to bleed all 4, one at a time.
Make sure the cap for the brake fluid is tight before attempting to bleed.
Intionally your looking for flow of the fluid without bubbles not a hard pedal. After a couple rotations you should see a hard pedal.
sublime2 is offline   Reply With Quote
The Following User Says Thank You to sublime2 For This Useful Post:
ben's plumbing (07-13-2013)
Old 07-13-2013, 06:20 PM   #3
Rewards Points: 13,300
Slowly depress the pedal, do not release it until someone has closed off the bleeder valve. Repeat.
The front and back should be two different systems, only work on one set at a time.
Old 07-13-2013, 06:37 PM   #4
I have gas!
That's exactly what I did, 3 times, and there's no air coming out but it seems there's air trapped somewhere. In the past, I've successfully replaced calipers and master cylinders but this is the first time replacing brake lines.
There's got to be something I'm missing or a method of bleeding that is different than the standard, open bleeder, depress pedal to floor, close bleeder, release pedal, repeat.
Old 07-13-2013, 06:58 PM   #5
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Try a search on YouTube.
Found many a video showing how to fix things.
https://www.youtube.com/watch?v=eZpe...e_gdata_player
Old 07-13-2013, 07:19 PM   #6
Oso954's Avatar
Rewards Points: 766
You probably need to cycle the ABS module.
It takes a special scan tool to do it.
Or some guys report success by driving car (if they have enough brakes) and braking hard enough to activate the ABS module. Then re-bleeding brakes.
Otherwise, call brake shops and ford garage to see if they have the scan tool to cycle the ABS module. IF they do, have them bleed the brakes.
Oso954 is online now   Reply With Quote
Old 07-13-2013, 07:26 PM   #7
Does your car have a proportion valve? Under m/c two lines go into a proportion valve. If u r not getting any air u may need to cross bleed the system. Bleed a little out of the left front then the right rear. If this does not help try the other corners. Needles to keep the m/c full. Also when bleeding don't let the person foot go all the way to the floor. U control this, them them, " down" push on the peddle, you just let a little fluid out, then tell them again. Also with ANY peddle pressure check the new lines for leaks. Hope this helps
Burgiebill is offline   Reply With Quote
Old 07-13-2013, 07:30 PM   #8
Originally Posted by Burgiebill
Does your car have a proportion valve? Under m/c two lines go into a proportion valve. If u r not getting any air u may need to cross bleed the system. Bleed a little out of the left front then the right rear. If this does not help try the other corners. Needles to SAY keep the m/c full. Also when bleeding don't let the person foot go all the way to the floor. U control this, tell them, " down" push on the peddle, you just let a little fluid out, then tell them again. Also with ANY peddle pressure check the new lines for leaks. Hope this helps
Forgot a couple of words,
Old 07-13-2013, 07:31 PM   #9
Rewards Points: 392
Try cracking the right rear cylinder bleeder valve and leave it open until brake fluid starts streaming out. Close that bleeder and repeat on the left rear. Sometimes it helps to tap on the cylinder to release trapped air. That should get you in the ballpark where you should start getting some pedal pressure to start the bleeding process. Always start at the cylinder farthest from the master cylinder.
rustyjames is offline   Reply With Quote
Old 07-13-2013, 07:40 PM   #10
I miss a couple of words,
Needles to sat keep the m/c full
Old 07-13-2013, 08:05 PM   #11
I have gas!
Interesting, cross bleeding... I haven't thought of that. Yes, two lines go into a proportion valve and yes, I'm not getting any air out.
Does the order of bleeding really make a difference? I always start at the far corner and work my way toward the mc (Right Rear, LF, RF, LF).
Why not push the peddle to the floor?
Old 07-13-2013, 10:14 PM   #12
It does not take a lot, if u have a pretty good peddle just a little then to left front. If not try the other corners. Good luck. Bill
Old 07-13-2013, 10:19 PM   #13
Sorry, we never pushed to the floor, it took a little longer but not much chance of sucking back air. Worked in a brake and front end shop, the worked for a Chevy dealership for about eight years. Plus all the destruction I could do to my own cars when I was young. A lot of "school of hard learning"
Old 07-13-2013, 10:32 PM   #14
Sorry, rustyjames is correct, do the right rear then left front. THEN do the left rear next right front.
Old 07-14-2013, 06:25 AM   #15
"You have to bleed all 4, one at a time."
Really and how do you do this?
Hardway is offline   Reply With Quote
Hot water problems - not sure what's causing it ngk Plumbing 6 03-29-2013 07:42 PM
Pendant Lamp Electrical problems JeffDIY Electrical 1 10-11-2012 04:36 PM
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 02:51 PM
Are you having ice problems? Grumpy Roofing/Siding 27 02-17-2008 04:51 PM
2005 Dodge brake wiring schematic dwallace Automotive Repairs 2 09-10-2007 08:48 AM
