Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 01-17-2013, 04:38 PM   #1
Pro Flooring Installer
rusty baker's Avatar
Brake hose plug
Anyone know of a way to plug a brake hose temporarily? I have a car that the caliper is leaking fluid in a stream. I need to drive the car across town to a friend's garage to fix it. Too cold to fix it outside.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 01-17-2013, 04:50 PM   #2
Brake hose plug
Not a great plan, but an inverted flare fitting with a cap should work, drive slow.
http://www.bing.com/images/search?q=...975FDE&first=1
Even with that there's still going to be air in the line so you will only have 1/2 the brakes?
Far better to get it towed.
Old 01-17-2013, 05:45 PM   #3
Brake hose plug
This is a GM brake hose. It has a banjo bolt through the caliper end.
Old 01-17-2013, 06:13 PM   #4
Master General ReEngineer
Bondo's Avatar
Brake hose plug
Ayuh,..... Vise-grips,.... Pinch it Tight,....
You'll need to replace it, along with the caliper...
Old 01-19-2013, 09:05 AM   #5
Brake hose plug
Pony up for the tow, your going to kill someone. One caliper will work full power and whip you into the other lane. You will die. If you do use the vise grip method then duc tape the handle shut
paintdrying is offline   Reply With Quote
Old 01-19-2013, 11:08 AM   #6
Brake hose plug
put a nut & bolt with the copper washers on the line.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Repairing Garden Hose Connection cl6120 Plumbing 9 09-12-2012 10:20 AM
Lennox furnace hose jwhvac HVAC 19 01-27-2012 09:16 PM
Moving Electric Range Plug dmartins Electrical 3 11-23-2010 08:48 AM
20 amp plug MikeyP Electrical 6 01-03-2009 10:04 PM
Avanti Electric Oven - But no Plug ? hongtea Electrical 4 03-16-2008 09:07 PM
