Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 01-15-2013, 05:23 PM   #1
Bleeding Brakes
Replaced a broken brake line on my 99 Ford F-150 and refilled the master cylinder, bled all four calipers. Brake petal felt good. Soon as I started the truck the petal went to the floor and keeps going to the floor every time I pump the brakes. I checked for more leaks and there are none and the master remains fool. ???????????????
teh3515 is offline   Reply With Quote
Old 01-15-2013, 08:23 PM   #2
ukrkoz's Avatar
Bleeding Brakes
Bad master. As in - piston seals or O-ring, whatever it has, blows fluid by.
ukrkoz is offline   Reply With Quote
Old 01-15-2013, 08:53 PM   #3
Bleeding Brakes
Unfortunately it could be a lot of things. The pedal suddenly falling when the engine starts is normal because that's when the brake booster kicks in. Obviously it shouldn't fall all the way to the floor though. If your master cylinder went dry when you replaced the line, you may need to "bench bleed" it (look it up). It is also possible that your Master Cylinder is bad as Ukrkoz mentioned. It could also be that you didn't properly bleed your brakes. Or . . .
I'd suggest browsing the brake forum on http://www.f150online.com/forums/ . Just be careful if you run into the threads about adjusting the rod depth on the brake booster, that's probably not your problem and is a tricky issue.
BTW, I have a 97 F250, and have replaced all the lines. If you live in the snow belt (like I do), your lines are probably as rusty as mine were and once one goes, the rest will be going over the next couple of years.
wrongdave is offline   Reply With Quote
Old 01-15-2013, 10:40 PM   #4
Bleeding Brakes
if they were working fine before = 99.99% chance that you didn't bleed properly. this is ASSuming that the other work was done correctly.
DIY'er, out of necessity. if i did this for a living, i would make about $3.50 an hour
i didn't make this world. i just live in it.
be careful of whom you make fun of. one day, that could be you...
Fix'n it is offline   Reply With Quote
Old 01-15-2013, 11:09 PM   #5
Pro Flooring Installer
rusty baker's Avatar
Bleeding Brakes
With a power booster, they need to be bled with the engine running. Otherwise, you won't get all the air out.
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
The Following User Says Thank You to rusty baker For This Useful Post:
joecaption (01-15-2013)
Old 01-16-2013, 12:48 AM   #6
" Euro " electrician
frenchelectrican's Avatar
Bleeding Brakes
There is two ways I always done with brake work.,
First methold which you will have a helper to help you on this one what you will do is pump the brake until firm and have a helper turn open the bleeder valve but a little a time and repeat as need to be and MAKE sure you do NOT let the fluid go below half level otherwise you will restart the whole thing over.,
Start at the furtherst one first useally right rear most case then left rear then right front then left front which this is most common and also a tip if everthing is working good but feel uneven blance on brakes what I do is crack open both front and back and hit the pedal not much but just enough to get the equizer valve back in place.
That methold is used with two peoples but if you are working alone you could buy a one way bleeder valve which it will include a check valve inside of it so you can pump couple time but be aware how much fluid it will go down so pump no more than two time and close the bleeder and refill the brake cylinder tank.
The other methold I used from time to time if you are not super hurry what I do is fill the brake cylinder and let the gravity take care of it for a while but keep your eyes on the master cylinder to not let it go below half level I did mange it few time before ( this is one of few metholds you really have to know what ya doing )
Hope that help ya with the info.
Merci,
Marc
Old 01-16-2013, 07:09 AM   #7
Bleeding Brakes
Merci,
Marc
That's fine, but with power brakes, the helper needs to pump the brakes with the engine idling.
Old 01-16-2013, 12:55 PM   #8
Bleeding Brakes
If you have anti-lock brakes, air can get trapped in that system. The Factory Service Manual set of books (order from dealer) will give detailed bleeding instructions including bleeding anti-lock brake systems. This might entail "cycling" the anti-lock brakes with a special electronic tool for the bleeding process.
Billy_Bob is offline   Reply With Quote
Old 01-17-2013, 06:26 AM   #9
Bleeding Brakes
I bled a few brakes over the years, and only a year ago, replaced a caliper on my vehicle. Never have I have the engine idling while bleeding the brakes, and the GM Service manual makes no mention of it. My peddle feels like the day I drove it off the lot new. My experience.
polarzak is offline   Reply With Quote
Old 01-17-2013, 12:29 PM   #10
Bleeding Brakes
There's no need to have the car running, to bleed the brakes, if the car has power brakes. Once the vacuum is released from the booster, you've got direct contact with the MC piston, bleed away....that being said, I'm strictly referring to vacuum assisted power brakes, I have no idea if a hydroboost set up requires a different procedure.
The mention of ABS is spot on, as that can impact how brakes need to be bled if the lines are cracked pre-ABS module. One of my cars has a specific tool for that, it does that among other things, and it's pretty expensive for a typical DIYer to run out and buy. The fact your pedal keeps going to the floor means one of two things - a massive amount of air in the system getting compressed, or as mentioned prior, a leaking MC piston.
Another option, if any local parts stores have them for rent, is to get a pressure bleeder, and bleed again to see what comes out. When used properly, those make the tedious process of bleeding brakes a walk in the park.
Chokingdogs is offline   Reply With Quote
Old 01-18-2013, 01:08 AM   #11
Bleeding Brakes
The Hydroboost verison do use the same procedure as convental vaccum booster is. So there is no differnce on that due all my trucks I have are diesel and used Hydroboost system.
The pressure head adpator that can fit top of the master cylinder will do the good trick with it ( useally work very well with non ABS but with ABS system it will be little differnt ) and with ABS you may need to get a adpator or speical tool to cycle the ABS pump / pressure resvoir (tank )
Merci,
Marc
Old 01-19-2013, 09:02 AM   #12
Bleeding Brakes
you blew the seals in the master cylinder. Buy new not a reman
paintdrying is offline   Reply With Quote
Burnishing or bedding in new brakes polarzak Automotive Repairs 4 10-25-2012 10:33 PM
Electric Trailer Brakes and Tires Condition Questions DIYguy2000 Automotive Repairs 10 09-18-2012 09:15 AM
New brakes pulsating shanecurran Automotive Repairs 17 07-06-2011 03:06 PM
bleeding hot water boiler baseboards kmwhite Plumbing 1 01-16-2011 09:55 PM
Trailer Brakes NEED HELP plz Jeepster Automotive Repairs 4 09-13-2009 07:45 PM
