Battery Terminal Corrosion - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 09-07-2012, 09:06 PM   #1
Rewards Points: 2,638
Battery terminal corrosion
I have an old Triumph that gets little use. I put a battery tender on it every once in a while (I get nervous about leaving it plugged in full time). Not surprisingly, I have issues with battery life. My current battery for a long time has shown a lot of corrosion on the positive terminal. Is this just par for the course, or is the battery defective/gone?
SPS-1 is offline   Reply With Quote
Old 09-07-2012, 09:18 PM   #2
I'm Your Huckleberry
Rewards Points: 2,270
What's a battery tender? No harm in leaving the battery connected and starting the car a few times a week, letting it run until it's warm.
"The sulfuric acid used in batteries produces hydrogen gas, which is the primary factor behind the corrosion process that naturally occurs on your battery cables. That is because when your vehicle and battery are operating, very small amounts of gas are released through the vent cap. When released, these fumes naturally combine with the heat, dirt and humidity in the air, plus other active agents under your hood, like grease, oil and coolant, to form corrosion on your battery cables and terminals."
Read more: http://wiki.answers.com/Q/What_cause...#ixzz25wUJ9g7u
http://www.titanspot.com/Titan/index.php?showtopic=7994
"Flooded Valve Regulated Lead Acid Batteries (VRLAB)
Flooded or vented lead acid battery The oldest types of lead acid batteries are flooded cell types. These have been around for decades and evolved from wooden box models into the plastic valve regulated models on the market today. The electrolyte in these batteries is liquid sulfuric acid solution. This stuff is pretty corrosive and has destroyed more than a few sets of clothes and pieces of RV gear. VRLA flooded batteries generate and vent dangerous explosive gases through their valve regulation and must be vented to the outside world. These batteries also acid "mist" during charging and discharging. This leads to the corrosion of their terminals, and often-acid damage to surrounding surfaces. (look at your car battery for an example) VRLA Flooded batteries must be installed upright, can leak that acid, and require regular watering. Should they fail to be watered, they will not perform to spec."
Hope all that helps!
Thanks.
Doc Holliday is offline   Reply With Quote
Old 09-07-2012, 09:50 PM   #3
Rewards Points: 13,732
There's lot of sealers for patterty terminals avalible at any auto parts store that will take care that.
Even a coat of Vasoline will work.
Old 09-08-2012, 06:04 AM   #4
Rewards Points: 254
Not a problem leaving the battery tender plugged in. I leave my motorcycle plugged in all winter my battery is now 8 years old and works great. Baking soda and water works great for cleaning the battery acid off.
cjm94 is offline   Reply With Quote
Old 09-08-2012, 07:57 AM   #5
Rewards Points: 104
Yes, as Joe mentioned, you can get felt gaskets, as well as the red baterry terminal paste at virtually any auto parts stores, and they can be effective. You obviously have other things going on under the hood as well, crankcase venting, etc., and the felts will get matted with time, so just remember to take a look at them once in a while. It has been too long since I have been under the hood of one of them, so can't remember enough details to know how much of a job it might be to switch the cables, etc., but side post batteries ar constructed such that the problem is much less with them.
Old 09-08-2012, 09:41 AM   #6
Household Handyman
Rewards Points: 1,408
A trick I learned fifty or so years ago, this works for "post" type batteries and motorcycle batteries: Put a light coat of general type grease on the top of the battery around the post, do not get it on the post. Place the cable end on the battery and tighten it up, then coat the cable end with this grease. This does not work well with the side post type batteries.
Old 09-08-2012, 11:25 AM   #7
Well, I cleaned it up, charged up the battery, replaced the clamp bolts with SS, put some grease on the bottom of the post, and called it a day. Car would not crank, and I thought it was the battery, but seemed to have been the clutch switch was not quite making.
Old 09-08-2012, 08:49 PM   #8
ukrkoz's Avatar
Rewards Points: 952
1. here's your best buddy # 1
http://www.wisegeek.com/what-is-dielectric-grease.htm
2. here's your best buddy #2:
http://www.permatex.com/products/aut...tor_Sealer.htm
which I do both, in this specific order, on all cars we own.
ukrkoz is offline   Reply With Quote
Old 09-10-2012, 08:24 AM   #9
Rewards Points: 304
SPS-1...is that a Triumph motorcycle or car? I had a TR-7 for many years, until it became a chain around my neck. Ah...the stories I could tell.
I used petroleum jelly on the terminals and it seemed to work well. Ukrkoz's solution is probably a better one. That is what I would use today if I had those old style battery terminals.
polarzak is offline   Reply With Quote
Old 09-10-2012, 11:05 AM   #10
Its a car. Spitfire.
It's in pretty good shape actually. But its still a mid seventies British car. So I do get the opportunity to work on it.
Old 09-10-2012, 01:31 PM   #11
Rewards Points: 304
Mine was 77 TR-7. Fun car, but those Lucas electrics??? I used to enjoy the "opportunity" to work on mine also, but it eventually became a "demand". I see a green Spitfire going up and down Highway 400 (Toronto) every once and a while. It is a nice car, brings back memories of my British car days....fond memories but I am glad I sold it when I did.
Old 09-11-2012, 05:32 AM   #12
Master General ReEngineer
Bondo's Avatar
Rewards Points: 1,360
Ayuh,.... The Prince of Darkness,....
Many years ago, I was into Austin Minis,...
Bondo is online now   Reply With Quote
Old 09-11-2012, 06:31 AM   #13
Haverhill Trade 1965
We used regular grease in the Army. Terminals, (posts and clamps), have to be cleaned with wire brush or scraper until shiny to remove any hard whitish coating. Don't use sandpaper, it can leave grit embedded that reduces contact. Check where the post comes through the casing for tiny leaks of acid, Baking soda will clean the corrosion but do not get any in the battery it will neutralize the acid. Reassemble and grease. We did this as if our life depended on it, and it could.
Duckweather is offline   Reply With Quote
Old 09-25-2012, 05:15 PM   #14
Smile
Once you've cleaned the terminals and tightened them back up ,use some permatex aviation gasket sealer on the terminals , it's cheap, works well, and can be used for a lot of other car related things. It leaves a shiny red impervious coating on the metal parts too!
autobell2 is offline   Reply With Quote
Battery light stays on when car is off!!!! crankbait09 Automotive Repairs 32 11-03-2015 08:07 AM
weathertron Mecury Thermostat VickiL HVAC 4 02-06-2011 04:32 PM
Help with Battery Terminal Cover/Socket/Switch LordX Electrical 13 05-03-2009 09:13 AM
Old UPS to car battery? pcampbell Electrical 8 01-20-2009 05:34 PM
