Battery Light Stays On When Car Is Off!!!! - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 06-09-2011, 06:38 PM   #1
Rewards Points: 335
Exclamation
Battery light stays on when car is off!!!!
Hey all, I am a proud owner of a 2002 Chevy S10, 6cyl vortec. I am the original owner and have about 165k miles on the truck.
I can honestly say that I have had next to nothing go wrong with my truck minus brakes and normal maintenance items. But it has been a VERY DEPENDABLE truck.
I'm not engine savvy so I am posting in hopes of a quick response.
Last night when I got home, I turned the truck off like normal and noticed that my battery light/odometer light was staying on. This has never happened before. So I put the keys back in and restarted thinking that it could just be a computer brain fart. Not the case. Although the light did turn off after I started it up, I turned the key off and removed it. Battery light remained on as well as the odometer.
I started asking around and the people I spoke with seemed to think it was my alternator. So I took it on my own judgement to go purchase a new one in hopes that it would work. I installed the alternator today and to my surprise, it didn't fix the problem.
So by this point I can't return the alternator cause it has been installed. So I grabbed my multimeter and started testing the battery as well as the alternator and all voltages are perfect. All is well.
I started checking all cables and couldn't find anything loose. I took the terminals off the battery and checked them, no corrosion. Very Clean. SO I put them back on and continued to look around the engine for other possibilities. NOTHING. so by this point I am very frustrated, I walked over to the dash and checked to see if the light was on....IT WASN'T!!! THE LIGHT WAS OFF. WAHOO!!!!
Not sure what I did but maybe the battery terminal was loose or losing contact at some point. oh well i WAS happy.
About 4 hours later, I left to run to the store. Truck is running well and didnt think about it anymore. I get to the store, turn the truck off to go inside and guess what? The DAMN light came back on!!!!
I am at a total loss of what I can check next. Right now, when I am done driving it or if the truck will be sitting for a good amount of time, I am disconnecting the negative battery cable so whatever is drawing power from the battery will not be able to.
Can anyone lead me in a direction of what else I can check? I am trying to avoid the dealership at this point since I already wasted $150.
Please Help!
crankbait09 is offline   Reply With Quote
Old 06-10-2011, 05:47 PM   #2
ukrkoz's Avatar
Rewards Points: 934
you may have parasitic draw from battery, and computer is smart enough to tell you this. my wife's Lexus turns little yellow light bulb on dash if one of the light bulbs is burnt.
i'd start with removing ECU fuse overnight, to see if it's gone.
if the car is turned off, it has nothing to do with alternator.
sometimes a simple thing like cabin light left on can do this.
also, read codes at parts store, just for the heck of it.
ukrkoz is offline   Reply With Quote
Old 06-10-2011, 09:08 PM   #3
Rewards Points: 46
I would be suspicious of the ignition switch, or possibly a couple of wires touching at that point.
Old 06-10-2011, 09:30 PM   #4
Rewards Points: 335
ok, i will double check. but if the light is now off, im searching for something that is not there.......................that light is not on at all anymore
Old 06-10-2011, 09:54 PM   #5
ukrkoz's Avatar
Rewards Points: 934
it is very hard
to find a black cat
in a pitch dark room
especially if the cat
is not there
Confucius
Old 06-10-2011, 10:03 PM   #6
Rewards Points: 46
I agree with ukrkoz; I don't generally try to avoid potential problems, but if the problem has gone away on its' own, I would not go looking for it. If it were a starter problem, or something like that, yes, you may find arc marks, or whatever, but not very likely in this case.
Old 06-10-2011, 10:05 PM   #7
ukrkoz's Avatar
Rewards Points: 934
he has it fixed. buddy of his, a real mechanic, not like us here, traced it down to - what's new - dashboard. stupid me, I forgot it's GM product.
Old 06-10-2011, 10:26 PM   #8
Rewards Points: 335
not sure if I said something wrong UKRKOZ, but I would like to thank you all for the advice..............It was much appreciated.
I was able to dodge the bullet of having to dish out more money, at the moment
Old 06-10-2011, 10:30 PM   #9
ukrkoz's Avatar
Rewards Points: 934
oh, no no, you good. it's this:
What lesson have I learned? Start off by getting car looked at by a mechanic and not assume I can be a rent-a-cop.
no, we are not mechanics here. tree shade ones, but that's about it. i still don't get rent-a-cop thing though..
yes, GM has ****ty clusters, that's a fact. so is mine in my Silverado. fuel gauge.
Old 06-10-2011, 10:39 PM   #10
Rewards Points: 335
ok, cool, just looked in to that last comment too much!!
take care everyone
Old 06-19-2011, 11:10 PM   #11
bubbler's Avatar
Rewards Points: 256
I have a '00 S10 ... the light and odo come on when you turn the key one click forward from "lock", this is before you see all other lights, etc turn on (that's "run").
I suspect a bad ignition switch...
bubbler is offline   Reply With Quote
Old 07-18-2011, 11:38 AM   #12
Rewards Points: 335
hmmmm, now I'm wondering about the ignition switch......
It has been roughly a month since I posted about this and allow me to give you a run down, since I last commented.
I was told that the "cluster" could be causing the issue, and that the load of this wouldn't kill the battery in just a days time of not running. So as I continued to drive it, the light went off and would only come on every once in a while. Very inconsistantly.
Well, the past few days, the light has remained on while the truck wasnt running. This morning, when I went out and tried to start it to go to work and NOTHING. Lights were on inside the truck, radio came on and all seemed fine but I got nothing but a loud clicking noise from under the hood. So now, I'm thinking that it is not the cluster.
The alternator is new (couple months old) and the starter is fairly new (maybe a year old).
What could be causing this? If it could be the ignition switch, how do I go about testing it?
Old 07-18-2011, 11:57 AM   #13
bubbler's Avatar
Rewards Points: 256
A few thoughts--
- I don't recall if you said you replaced the battery or not? If it's not a new battery (under a year old), I'd consider replacing it now that you've run it dead a few times with this problem
- The "clicking" despite having lights/radio is classic weak battery--my guess is that your lights/radio dim to almost non-existent when you have the key turned to start (and hearing the clicking)?
- Just because the alternator is "new" doesn't mean it is working, you probably have a rebuilt alternator and it's possibly it is not working properly, you should have it tested at a place like Autozone (they wheel a cart out hook a big inductive ammeter to your battery cables and alternator output then apply various loads to test things out. It's possible your alternator is not outputting as much current as it should. This will NOT cause the battery light to illuminate with the ignition switch OFF, but may cause it illuminate when running--does your voltmeter show at least 12.4V when the truck is running (ideally it should be 13-14.5V when running just above idle or faster)
- How to go about testing the ignition switch... well, I'd say disconnect the battery and then test for continuity (and resistance) between the feeds into the switch and the feeds out of the switch. Based on your description (odo and battery light remain on w/ switch in LOCK and key removed) it sounds like this is pretty clearly the problem. So you want to see that the circuits that are supposed to be closed are closed (close to 0ohm) at the right positions, and the circuits that should be open are open (open line or maybe in the mega-ohm range at worst) at the right positions... If you have a Haynes manual or something similar it should have an ignition switch wiring diagram somewhere
Old 07-18-2011, 12:08 PM   #14
Rewards Points: 335
The battery is not new. When I first ran in to this issue about a month ago, I had my battery checked and all was well. Voltages were showing up the way they were supposed to. So I took that out of the equation. Since then, this was the only day I couldn't get the truck to turn over.........Even after jump starting it with my wifes car.....NOTHING but the clicking
"The "clicking" despite having lights/radio is classic weak battery--my guess is that your lights/radio dim to almost non-existent when you have the key turned to start (and hearing the clicking)?" I will check this tonight when I get home...
When the truck is running, I have no dash lights that come on, everything runs normally.
I will check the manual tonight for the wiring diagram and see what I come up with.
Thanks for your help, I will keep you updated. (This time I'm not going to start replacing parts till I know for sure of the problem )
on a side note, I notice that when this battery light is on and the key is removed......the truck alarm system will not activate when I push the remote button. But when the light is off and all appears normal, the alarm can be set when exiting the vehicle................
Old 07-18-2011, 01:01 PM   #15
bubbler's Avatar
Rewards Points: 256
How did they check the battery? A simple voltage test is not sufficient, it really needs to be load tested. Another thing, depending on where you bring it the "testing" is very suspect. I brought a battery to AZ for testing once, the test came out "charge too low, charge first then re-test", so they charge it (incidentally they charge at about 100A+/hr which is murder for battery life) then almost immediately re-test it and it will test as good... however I let the battery sit overnight (outside the car), brought it back for re-test, got the same result "charge too low, charge first", I told them no way, you need to warranty this thing because it is not holding a charge even when not installed in the car.
The fact that the truck has been starting is a pretty good sign the alternator is working...
Couldn't jump w/ her car... what is your procedure? A poor connection at either car might not result in much current getting through. Are you idling your the good car up to at least 1200rpm for at least 5-10 mins?
When you say clicking... do you hear repetitive & fast click-click-click-click-click when you hold the key in START, or do you hear just a single click? If it's just a single click it's possible the starter has an issue... a friend w/ a VW had the braided cable between solenoid and starter go bad, so he'd hear the click of the solenoid, but that was it... this was solenoid mounted on the starter too, so it was an "integrated" unit...
If you suspect the starter, the lights stay bright when the key is in START you might have someone repeatedly move the key between RUN and START while you give the starter a few smacks w/ a hammer or tire iron (just make sure you're clear of moving parts!) ... I had a Cadillac w/ a bad starter, giving a wack w/ the tire iron while someone held the key in start would get it going.
Pilot light button on furnace won't turn whydonchathen HVAC 8 01-19-2015 11:40 AM
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 05:28 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 09:19 PM
Whirlpool Microwave light issue mustangcobra44 Appliances 8 08-14-2008 04:52 PM
