Battery Dying - Automotive Repairs - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 07-21-2010, 04:13 PM   #16
Rewards Points: 392
Originally Posted by canadaclub View Post
Got a boost this morning and let it run for about 45 minutes. Then I went for a long drive, about an hour.
I put a meter between the neg side of the battery and the cable. It read 0 but flickered off and on with 1 miilliamp. I then did a voltage reading and got 12.97 vdc. I waited an hour and it read 12.54. Was enough to turn over the engine once but not enough to start. At least I had enough power to shut the window because its supposed to rain.
So, next I disconnect the neg terminal again and waited for 2 hours. Voltage now is 11.99vdc. I guess the battery is shot. Sheesh, I've only had it 6 months.
I also disconnected the red lead while the car was running and it continued to run so I assume the alternator works fine.
Sure appreciate the help folks. Tomorrow I'll take it in and get a replacement.
That's not a good way to test your charging system, and it doesn't indicate that the altenator that is not discharging the battery.
rustyjames is offline   Reply With Quote
Old 07-21-2010, 05:45 PM   #17
Handyman
Rewards Points: 512
Hmmm...can you expand on that?
canadaclub is offline   Reply With Quote
Old 07-21-2010, 07:47 PM   #18
I would not conclude that your battery is shot.
Do not disconnect the battery when the car is running.
Old 07-22-2010, 04:13 AM   #19
Rewards Points: 392
A bad diaode will allow it to charge, but drain the battery.
Old 07-22-2010, 12:20 PM   #20
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 82
With the car turned off and everything on the car turned off, underhood light, trunk light, dome light, etc. Disconnect the hot cable, if it sparks, you have a short.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
rusty baker is online now   Reply With Quote
Old 07-22-2010, 12:35 PM   #21
Handyman
Rewards Points: 512
Well, picked up a new battery today, swapped it out, and works like a charm. Thanks again all for the help
Old 07-22-2010, 12:51 PM   #22
So the old battery was sulphated?
Coulda' fooled me. Usually these crank the engine fast at first and then rapidly slow.
Old 07-23-2010, 09:59 PM   #23
cowboy dan's Avatar
with the new battery installed how does it charge now? i read that it was charging at 12.5v. is it still charging at 12.5? if it is your new battery will soon die. you ignition requires 12 by itself. you should have 14v charge and more on cold days. no less than 13.5 in order to use your accesories without putting too much load on the battery
cowboy dan is offline   Reply With Quote
Old 07-24-2010, 09:27 AM   #24
Rewards Points: 82
A voltmeter won't read correctly on a bad battery, so he original readings don't matter.
Old 07-24-2010, 06:55 PM   #25
Say what?
Old 07-24-2010, 07:17 PM   #26
Handyman
Rewards Points: 512
Hmmm.I put a VM on a battery and you say its no good if its bad battery? Interesting. Then how would I know its a bad battery since the VM can't read voltage on a bad battery??
Old 07-24-2010, 07:31 PM   #27
Handyman
Rewards Points: 512
The new battery shows 14.3 volts. Starts like a charm. I can't tell how its charging because I only have an idiot light and no gauge.
Old 07-24-2010, 07:37 PM   #28
Then it's being charged. Anything above 12.8 means some current is flowing into the battery.
If the voltage stays at this value with the headlights and accessories being switched on and off then the regulator is also working.
You can also make an AC reading on your battery. Excessive AC ripple voltage means a problem in your alternator or high internal impedance in your battery.
The problem is, I don't know pass/fail limits or test conditions for this ripple voltage.
Old 07-24-2010, 09:19 PM   #29
Rewards Points: 82
If you put a voltmeter on a battery in a running vehicle and it reads less than 14, It can be either a low battery or a faulty charging system. So it means nothing. If you know the battery is fully charged, and it reads less than 14, it is the charging system.
APC Battery Backup - Extending Run Time with BIG Battery Bank homerb PC Repairs & Upgrades 31 05-03-2012 05:40 PM
Has anyone tried this way of fixing a dead cordless tool battery? BJLower Electrical 11 02-01-2010 01:31 PM
Old UPS to car battery? pcampbell Electrical 8 01-20-2009 05:34 PM
Milwaukee v28 Battery Life r62ewa Tools 12 12-04-2008 06:58 PM
Ryobi 12v battery system JElson Tools 3 10-11-2008 09:50 PM
