Battery Dying - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 07-20-2010, 01:10 PM   #1
Handyman
Rewards Points: 512
battery dying
Having a heck of a week here Can anyone tell me the best way to isolate whatever is killing my battery overnight?
No lights left on but every morning its dead. Battery is only 6 months old.
canadaclub is offline   Reply With Quote
Old 07-20-2010, 01:47 PM   #2
Household Handyman
Rewards Points: 1,408
Need more info on the particular vehicle, why? IF it is a GM vehicle 2007 model year of after, there were a lot of BCM's (body control modules) which would not shut down as they should have. This would create a "parasitic" draw in the electrical system and kill a battery in about six hours. The dealer's have the TSB's (Technical Service Bulletins) on this and instructions on how to perform the test over a 24 hr. period. Ask me how I know all of this. David
Old 07-20-2010, 01:56 PM   #3
Handyman
Rewards Points: 512
Thanks for the reply David Unfortunately I'm not rich enough to afford that vehicle Mine is a 98 Ford Windstar
Old 07-20-2010, 01:59 PM   #4
Registered User
Rewards Points: 526
http://www.wikihow.com/Find-a-Parasitic-Battery-Drain
Be safe, Gary
Old 07-20-2010, 04:03 PM   #5
Rewards Points: 392
Quite often, if it's not something such as a light on or something like that, it'll be the altenator.
rustyjames is offline   Reply With Quote
Old 07-20-2010, 04:41 PM   #6
For a 60 A-h battery to die in 8 hours you're looking for at least a 7A drain. That much current has to make heat, light or noise.
Normal parasitic drain might be less than 100 mA.
Old 07-20-2010, 04:56 PM   #7
Handyman
Rewards Points: 512
Since I bought the vehicle, used, the chime sets off like I still have the keys in the ignition...no big deal. I noticed a clicking sound from the fuse panel, even under low power. I took out the relay which was labelled auto lights...even though I dont have have auto lights...hoping that was the problem. Still a dead battery. If I put an amp meter on, what reading should I expect to see? I suppose I will have to pull fuses one by one.
Since all of my friend is working, is it possible to do an Amp check myself? I thought that the use of booster cables may work, being 4 conductor, but has anyone tried this?
Old 07-20-2010, 04:58 PM   #8
Handyman
Rewards Points: 512
Sorry Gary, I missed your post,,I will try that tomorrow and thanks
Old 07-20-2010, 05:08 PM   #9
This reminds of something.
Let's say the regulator was bad and the car's electronics were exposed to 17 vdc for months on end. As the battery electrolyte boiled out the previous owners just replaced the batteries, thinking they were defective.
If this is true, the car is creamed even though everything looks fine.
It could also be that your battery is low in charge. With the engine running at a fast idle and all acc. off you should be seeing at least 13.3 vdc on your battery. In the winter it could go to 15.5 vdc.
Old 07-20-2010, 05:12 PM   #10
Handyman
Rewards Points: 512
But it runs fine after a boost..just loses charge over night
Old 07-20-2010, 05:20 PM   #11
A boost doesn't fully charge it.
I ran an experiment back when I "was a kid": I purposely left on the headlights.
After 3 hours the headlights were still bright but the car wouldn't crank.
After 4 hours all was dead.
So I jumped it and went for a drive with the first wife and kids to recharge. Unfortunately I somehow stalled the car at the end of the block [it had auto transmission].
To my utter surprise it cranked as if the battery were fully charged but once running the ammeter was still way over on the charge side and stayed that way for almost four hours.
Welcome to "surface charge".
[My ex got that car].
[This forum is more fun when I'm half drunk].
Old 07-20-2010, 05:26 PM   #12
Handyman
Rewards Points: 512
I always turn headlights on after a boost to supply load, something I learned years ago and a good spin on the highway helps as opposed to just idle ( which I hear can do more damage to the battery?)
Old 07-20-2010, 05:29 PM   #13
Since your problem is reproducible rather than intermittent, with a DVM/clamp-on ammeter and with pulling fuses you should be able to find it.
Too bad you don't live near Rockville, MD. I cannot resist a challenge.
Old 07-21-2010, 01:19 PM   #14
Household Handyman
A '98 Ford Windstar is just fine. Hmmm, Windstar, van, sliding door on passenger side? I work for a friends auto parts store part-time (when needed, and often), I do go into many shops and hear stories at the store. Seems like somewhere in the back of my feeble mind there was a problem with a connection for interior lighting on Ford Windstar's and a similar problem with Chrysler vans some years back. Something to do with a "pin connector" where the door closes not making good contact and leaving the computer to think the door was not actually shut correctly. This MAY be a problem leading to a "Parasitic draw" on the electrical system. I would to the test Gary recommended-first. I would also highly recommend, if you have not done so, to purchase a "Haynes" or "Chilton" manual for your vehicle. NO, I don't make money off of these, they are valuable for anyone who owns a vehicle that does not have a warranty-IMO. David
Old 07-21-2010, 01:47 PM   #15
Handyman
Rewards Points: 512
Got a boost this morning and let it run for about 45 minutes. Then I went for a long drive, about an hour.
I put a meter between the neg side of the battery and the cable. It read 0 but flickered off and on with 1 miilliamp. I then did a voltage reading and got 12.97 vdc. I waited an hour and it read 12.54. Was enough to turn over the engine once but not enough to start. At least I had enough power to shut the window because its supposed to rain.
So, next I disconnect the neg terminal again and waited for 2 hours. Voltage now is 11.99vdc. I guess the battery is shot. Sheesh, I've only had it 6 months.
I also disconnected the red lead while the car was running and it continued to run so I assume the alternator works fine.
Sure appreciate the help folks. Tomorrow I'll take it in and get a replacement.
APC Battery Backup - Extending Run Time with BIG Battery Bank homerb PC Repairs & Upgrades 31 05-03-2012 05:40 PM
Has anyone tried this way of fixing a dead cordless tool battery? BJLower Electrical 11 02-01-2010 01:31 PM
Old UPS to car battery? pcampbell Electrical 8 01-20-2009 05:34 PM
Milwaukee v28 Battery Life r62ewa Tools 12 12-04-2008 06:58 PM
Ryobi 12v battery system JElson Tools 3 10-11-2008 09:50 PM
