Ball Joint Press - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 10-05-2013, 10:39 AM   #1
Rewards Points: 164
Ball joint press
I have a 90 ford 4x4 truck f-150 that needs ball joint replaced, what kind if kit should I buy?? Is there a specific one for this truck looking into buying one on e-bay?? Help!!!
bostonwindows30 is offline   Reply With Quote
Old 10-05-2013, 12:22 PM   #2
World's Tallest Midget
Mort's Avatar
Rewards Points: 692
If you live near an O'Reillys, they'll lend you one. That's kind of an expensive tool to buy unless you're going to do a lot of them.
The kits are universal, they just have different size adapters for different vehicles.
Mort is online now   Reply With Quote
Old 10-05-2013, 12:42 PM   #3
Rewards Points: 164
Is a bunch on e bay for 60 bucks
Old 10-05-2013, 01:00 PM   #4
Rewards Points: 164
Is that the right one?? One does all???
Old 10-05-2013, 05:22 PM   #5
Rewards Points: 164
I have 4c4 is that what I need looks like they all do three different sizes???
Old 10-05-2013, 06:56 PM   #6
Rewards Points: 1,062
woah! i didnt know orileys rents out tools like presses. Good deal! I have to remember that! Got one nearby (first time locally ever in these parts!
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 10-05-2013, 07:22 PM   #7
Rewards Points: 164
I see a bunch on e-bay for 70 bucks, that's not a lot but o'reillys rents them if you put 130 bucks down then they will return it when you you bring part back, why not buy one??
Old 10-05-2013, 08:59 PM   #8
Ole Wood Worker
BigJim's Avatar
Rewards Points: 304
Are you talking about the fork to get the joint loose? If so you don't need one, just take the nut off, if you aren't going to use it again. The part the tapered bolt goes through, just hit it hard a few times with a heavy hammer and it will come loose, not the bolt, but the part it goes through. You may have to give it several good hard whacks but it will come loose.
New members: Please consider adding your location to your profile.
If you do what you've always done, you'll get what you've always got.
http://www.woodworkingtalk.com/forum.php
Jim
BigJim is online now   Reply With Quote
Old 10-05-2013, 09:00 PM   #9
Rewards Points: 164
It's a ford you need a press to get back in
Old 10-05-2013, 09:03 PM   #10
Rewards Points: 164
That would be good for a chevy
Old 10-05-2013, 09:09 PM   #11
Ole Wood Worker
BigJim's Avatar
Rewards Points: 304
I'm a lot behind with the cars and trucks today, I was a mechanic back in the early 60s for a while.
Jim
Old 10-05-2013, 10:46 PM   #12
ukrkoz's Avatar
Rewards Points: 946
Boston, for a few more bucks, you will have them swapped at any local tire shop or such.
Personally, I do not believe, you will save any by trying to DIY esp with thing you loan from O-Reilly. I tried them, they suck. Guys at shop have well crafted and working tools, it's a breeze for them to do the job.
Otherwise, what's wrong with hammering them out with large socket?
ukrkoz is offline   Reply With Quote
Old 10-06-2013, 05:09 AM   #13
Rewards Points: 164
To have a shop do it will cost huge, undo all my work myself, it's 4x4 so bearings need to be repacked.. Etc never mind I will buy one seems nobody has, a clue on here!!
Old 10-06-2013, 05:33 PM   #14
ukrkoz's Avatar
Rewards Points: 946
Dude, tame down. You said ball joints. Not bearings. You need to remove control arms and press old joint out and press new one in. A tire shop does this for like ten bucks a pop. JUst to make it perfectly clear - ON REMOVED CONTROL ARM. What repacking bearings has to do with this? 4WD hub bearings are replaced in about 20 minutes DIY and cost about $200 or so, more or less, depends where you buy them.
Respect fellow drivers trying to help you. Or don't ask questions and read repair manuals.
The Following User Says Thank You to ukrkoz For This Useful Post:
RoyalAcresRod (10-06-2013)
Old 10-06-2013, 07:33 PM   #15
Rewards Points: 164
Another one lol
Ball joint bostonwindows30 Automotive Repairs 37 04-01-2013 07:14 PM
Delta Ball Joint shower arm adapter??? nic3456 Plumbing 3 11-10-2010 10:01 AM
Can't get ball joint to separate from knuckle on '88 R10 1/2 ton 2WD Suburban TJMS81 Automotive Repairs 11 11-27-2009 10:11 PM
Ball and Socket Joint Question lateralan Carpentry 9 04-25-2008 09:12 AM
Control Arm - Self locking nut spins ball joint dkbaum Automotive Repairs 4 02-24-2008 11:56 AM
