Ball Joint - Automotive Repairs - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 03-25-2013, 10:08 PM   #16
Rewards Points: 164
So it will drill out a 1\2 " hole for each????
bostonwindows30 is offline   Reply With Quote
Old 03-26-2013, 05:45 AM   #17
r0ckstarr's Avatar
Rewards Points: 2,012
No, you'll only drill far enough down to break the head of the rivet loose. Then you can push the rivet out the other side.
r0ckstarr is online now   Reply With Quote
Old 03-26-2013, 06:13 PM   #18
Bigplanz's Avatar
Rewards Points: 974
Use the 1/2 inch bit to drill out the head. Use a 3-pound hammer and a 3/8 inch punch and drive out the rivet. Last time I did it I used a pair of channel locks to hold the punch. Hit the punch HARD. Thus the channel locks. Mis-hit it and you break your hand..
Bigplanz is offline   Reply With Quote
Old 03-26-2013, 07:10 PM   #19
Rewards Points: 164
What do u mean by a "punch" is this a certain tool???
Old 03-26-2013, 08:28 PM   #20
Bigplanz's Avatar
Rewards Points: 974
Yes. It is basically a metal rod that "punches" something in or out of a hole. A nail punch sets a nail below the surface of the wood. A machinist's punch will drive out rivets.
Old 03-26-2013, 08:30 PM   #21
Rewards Points: 164
Where can I get this???
Old 03-26-2013, 09:51 PM   #22
JOATMON
ddawg16's Avatar
Rewards Points: 1,454
Boston....no offense....but if you don't own a punch, much less know what one is....then your way in over your head at this point.
The Following User Says Thank You to ddawg16 For This Useful Post:
davido30093 (03-27-2013)
Old 03-27-2013, 03:24 AM   #23
Rewards Points: 164
Sorry.. Never had to use a set before,
Old 03-27-2013, 03:37 AM   #24
Rewards Points: 164
I am tacking this sat and looking for ideas this is going to save me a **** load of money mechanics Are way to over priced...
Old 03-27-2013, 03:48 AM   #25
r0ckstarr's Avatar
I completely agree. If you don't know what a punch is, then I find it very hard to believe that you understand the danger behind your torsion bars. Saving money is one thing, but saving your life is more important. How much is the mechanic versus the doctor bill?
Is your name Boston because that is your location, or are you located somewhere else? If you are local to me, I would be glad to show you how to do it.
I seriously suggest that you find a friend that has done this before to help you out.
Old 03-27-2013, 04:06 AM   #26
Rewards Points: 164
I think if I put pressure from a jack on the lower control arm getting hurt won't be a problem, I have seen a few videos on doing it...
Old 03-27-2013, 05:18 AM   #27
r0ckstarr's Avatar
Ok. I'll take your word for it. Good luck.
Report back afterwards and let us know how it went, or if you get stuck half way through doing it.
Old 03-27-2013, 06:25 AM   #28
Bigplanz's Avatar
Rewards Points: 974
jack up the control arm/torsion bar, put a jack stand under it and release the jack. that is more stable, particularly if you're going to be pounding on it with a three pound hammer. As long as the suspension is unloaded and supported by the jack stand it will be stable. Good luck. This is not a job for a rookie.
Old 03-27-2013, 06:43 AM   #29
Rewards Points: 164
It will be fun trying though, I find working on vehicles is very rewarding.. Thanks everyone for all the tips, thanks so much I will update everyone when I am done..
Old 03-27-2013, 06:02 PM   #30
Rewards Points: 83
This sounds scary. Please, at least, have someone there with you who can get help if something goes wrong.
Good Luck. Please report back on your success.
davido30093 is offline   Reply With Quote
Delta Ball Joint shower arm adapter??? nic3456 Plumbing 3 11-10-2010 10:01 AM
Can't get ball joint to separate from knuckle on '88 R10 1/2 ton 2WD Suburban TJMS81 Automotive Repairs 11 11-27-2009 10:11 PM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 05:50 PM
Ball and Socket Joint Question lateralan Carpentry 9 04-25-2008 09:12 AM
Control Arm - Self locking nut spins ball joint dkbaum Automotive Repairs 4 02-24-2008 11:56 AM
