Ball Joint - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 03-23-2013, 03:42 PM   #1
Rewards Points: 164
Ball joint
I have a 99 chevy blazer 4x4 v6 and both bottom front ball joints need to be replaced, they have rivets on them, any ideas?????
bostonwindows30 is offline   Reply With Quote
Old 03-23-2013, 03:53 PM   #2
Rewards Points: 736
Those Blazers hav ea pretty passionate fan base, there's problem a forum devoted to Blazers out there
TheBobmanNH is offline   Reply With Quote
Old 03-23-2013, 07:18 PM   #3
r0ckstarr's Avatar
Rewards Points: 1,988
You have to grind the heads off of the rivets, and then knock the shaft of the rivet through to the other side once the head is ground off. Depending on what brand of ball joints you get, they should come with new bolts to bolt the new ones in place.
I had both an '85 and a '91 Blazer (obviously different body style than yours), but that's how I had to do mine.
r0ckstarr is online now   Reply With Quote
Old 03-23-2013, 07:28 PM   #4
Rewards Points: 164
So grind heads first then try to knock out the rest with hammer and something sharp ????
Old 03-23-2013, 07:41 PM   #5
r0ckstarr's Avatar
You want to put the vehicle on jack stands and support the Lower Control Arm with a jack. When the ball joint breaks loose, the force of the suspension spring can seriously hurt or kill you. The jack will be to keep the LCA from swinging down once the ball joint comes free. Once it is free, you can slowly lower the jack to let it down. I don't know your how much experience you have working on cars, so I feel that it's safe that I mention the danger. A spring compressor may be needed to put the spring back in.
Here's a video showing the grinding of the rivets.
I also suggest what was said in the 2nd post of this thread.
Old 03-23-2013, 07:53 PM   #6
JOATMON
ddawg16's Avatar
Rewards Points: 1,116
Boston....having done it a few times.....your getting some real good advice there.....
It's actually real easy...once you dive in....but please follow the above advice....take your time and save the beer for when the project is done and your admiring your work.
ddawg16 is online now   Reply With Quote
The Following User Says Thank You to ddawg16 For This Useful Post:
r0ckstarr (03-23-2013)
Old 03-23-2013, 08:13 PM   #7
Rewards Points: 164
Mine is the lower ball joint, the rivets are on top and bottom
Old 03-23-2013, 08:15 PM   #8
r0ckstarr's Avatar
The lower control arm will be holding the force of the suspension spring.
Old 03-24-2013, 06:17 AM   #9
Rewards Points: 164
Should I try to drill it out, first?? And what size drill bit do I need???
Old 03-24-2013, 06:25 AM   #10
r0ckstarr's Avatar
Do you have any friends that have done this before? I'd really hate to see you get injured.
I suggest you watch some Youtube videos over the procedure to get more familiar with it. Just search for "ball joint rivets".
Old 03-24-2013, 06:28 AM   #11
Rewards Points: 164
I am pretty much mechanically inclined I have just rebuilt a 1500 chevy truck everything done myself put about 5k into it, but this ball joint is something new to me, just getting ideas before I tackle this...
Old 03-24-2013, 01:14 PM   #12
Rewards Points: 216
iirc, you don't have "springs". you have torsion bars.
Fix'n it is offline   Reply With Quote
Old 03-24-2013, 01:38 PM   #13
r0ckstarr's Avatar
The same principal still applies, but won't don't need a spring compressor.
Old 03-24-2013, 01:40 PM   #14
JOATMON
ddawg16's Avatar
Most torsion bars have an adjustment....hence, crank it all the way down to min to reduce the torsion.
Old 03-25-2013, 06:33 PM   #15
Bigplanz's Avatar
Rewards Points: 948
The shop manual says drill a pilot hole with a 1/8 inch bit in the rivet, then drill out the rivet head with a 1/2 inch bit. Using a low RPM, high torque drill will help.
Bigplanz is offline   Reply With Quote
Delta Ball Joint shower arm adapter??? nic3456 Plumbing 3 11-10-2010 11:01 AM
Can't get ball joint to separate from knuckle on '88 R10 1/2 ton 2WD Suburban TJMS81 Automotive Repairs 11 11-27-2009 11:11 PM
Joint compound to smooth old paint layers. gmhut Painting 1 05-03-2009 06:50 PM
Ball and Socket Joint Question lateralan Carpentry 9 04-25-2008 10:12 AM
Control Arm - Self locking nut spins ball joint dkbaum Automotive Repairs 4 02-24-2008 12:56 PM
