Automatic Transmission - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 05-05-2013, 08:16 PM   #1
dgbuonano's Avatar
automatic transmission
Hi guys, I'm starting a project of a car and I want to use the V8 302 engine from the old Ford galaxie/landau... The project is a small sport car, 2 sits. This engine is originaly used with a manual transmission on the galaxie/landau and I'd like to know if its possible to use an automatic transmission without problem, also if I'll have trouble installing it. I mean, considering that it will be possible, is it harder to install an automatic transmission than a manual one? Thank you!!
dgbuonano is offline   Reply With Quote
Old 05-06-2013, 02:05 PM   #2
Rewards Points: 736
Why on Earth would you build a custom car and put an auto in it? Blech.
TheBobmanNH is offline   Reply With Quote
The Following 2 Users Say Thank You to TheBobmanNH For This Useful Post:
BirdSlapper (05-07-2013), r0ckstarr (05-06-2013)
Old 05-06-2013, 03:25 PM   #3
Mold!! Let's kill it!
Rewards Points: 2,012
Why would you build a custom car/street rod and put a manual transmission in it? Really the clutch linkage can be the biggest issue on a swap like that, but there are hydraulic kits that let you adapt almost anything, as long as you have space for the cylinders. Automatic is easy, except you'll need to consider running a cooler or running an exchanger in the radiator. Almost everybody building street rods today runs an automatic.
Old 05-06-2013, 04:07 PM   #4
Rewards Points: 131
Putting in an auto transmission is exponentially easier than a manual, in a "custom" built car at least. I'm not too versed on Fords --that being said-- do you know if the engine was originally built ( from the factory ) as a manual? I don't know if the 302 was internally or externally balanced. If it's external balance, and it's factory, yanking the flywheel will throw it out of balance. If you're having the engine purpose built/machined, and it's known an auto will be going behind it, then nothing really to worry about. If you are not doing that, and simply dropping said engine into the car, you'll need to research more. Also, depending on the model Galaxy ( since you mention Landau, I'll assume a luxo model ) and what's been done to the engine, it could be a total slug in terms of performance.
Not knowing space considerations and the car's intended use ( track, spirited driving, or simply cruising ), you could use a Ford C4 ( smallest case/unit I'm aware of, but also the "weakest" ), a C6 ( bigger case and an "out of the box" beefier unit ), but both are 3 speeds, so final drive ratio is a potential concern. There's later model Ford 4 speed autos too, and I think some are quite durable, but then you'll have to decide on lock up converter or not, and how much you want to monkey around with an electronically controlled trans. I don't recall when the 302 block was killed by Ford, late 90s early 2000s?, so you should have numerous options for auto transmissions.
Chokingdogs is offline   Reply With Quote
Old 05-06-2013, 09:21 PM   #5
Lord of Slums
Rewards Points: 1,974
Not a ford guy as well. Basically the answer is you are doing something other than stock, their is always going to be a certain amount of fabricating involved. For example, something to do with the brackets that held the manual transmission linkage is different, so now you need to drill into the block to mount a new tranny bracket. Been so long ago I can no longer remember specifics. My point is, you will need to mess with stuff. I could take the engine out of my van and put it in a brand new truck. First problem is state emission tests. Next would be finding all the computers and software to try and get things to work. Another reason I love older stuff, carbs, no computer, everything was easier back in the day. But now you get to have this overly complicated car that only the dealer can fix. All the the sake of a few more mpg.
mj12 is offline   Reply With Quote
Old 05-06-2013, 09:30 PM   #6
dgbuonano's Avatar
I prefer the manual transmission too, probably I'll use it... I am just considering the automatic one, just studying the possibility to use it, but like you said, I'll probably have problems with the electronic part
Old 05-06-2013, 10:21 PM   #7
World's Tallest Midget
Mort's Avatar
Rewards Points: 694
You could get an AOD out of any 80s Ford and it should drop right in. No electronics required.
I hate signatures.
Mort is online now   Reply With Quote
Old 05-07-2013, 09:15 AM   #8
Rewards Points: 736
Originally Posted by Maintenance 6 View Post
Why would you build a custom car/street rod and put a manual transmission in it? ........ Almost everybody building street rods today runs an automatic.
Because driving an automatic is boring and horrible? I assume someone is going to build a custom vehicle because they want to enjoy driving it some day, and personally (I realize this is a personal preference) there are very few cars I would enjoy driving in automatic. I don't care what everyone else does, if I want a vehicle that's going to be fun to use, it's going to have a manual.
I'm sure an auto is easier to install than a manual, but it's also easier to just go to the car lot and buy a pre-built car. It's easier to just lay down and die than to do anything, really. If you make decisions based on what's easier you're not going to accomplish much.
Sorry for the derail, I know this is not what the OP asked Good luck man.
Old 05-07-2013, 12:06 PM   #9
Just as a heads up, 302s were externally balanced, and to make things worse, some years were balanced differently. Be sure to use the correct flywheel AND vibration damper for the year engine you use.
Transmission swap for 1998 Nissan Sentra Snav Automotive Repairs 1 03-19-2012 11:11 AM
DeWalt DW959K2 Transmission Issues TM1Ne Building & Construction 0 01-13-2012 08:59 AM
main burners cut out/ no automatic vent damper? Shevek HVAC 6 11-14-2011 12:33 AM
Transmission question for any experienced mechanics Richo Automotive Repairs 12 05-28-2011 11:17 AM
Transmission chevy motor automatic sharlani Automotive Repairs 6 07-23-2009 10:39 PM
