Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 01-16-2012, 08:47 AM   #1
old guy contractor
tcleve4911's Avatar
Automatic door locks not working
2003 Suburban
The front doors work okay but if I lock the rear doors and hatch, I can't open them unless I reach in back and manually flip the lock.
This is a pain since that doesn't work for the rear hatch.
To unlock the rear hatch and doors, I have to continually flip the driver's door lock on and off many many times and all of a sudden all the rear doors unlock.
What's the fix???...BTW my key ring lock doesn't work at all anymore but I still should be able to unlock all the doors from the driver door.....
tcleve4911 is offline   Reply With Quote
Old 01-16-2012, 08:53 AM   #2
47_47's Avatar
Does the passenger front door unlock?
What we've got here is... failure to communicate. Some men you just can't reach. So you get what we had here last week, which is the way he wants it... well, he gets it.
47_47 is offline   Reply With Quote
Old 01-16-2012, 12:40 PM   #3
First read your owner's manual as to the operation and any optional "settings" there may be for the door locks.
Sometimes there are child "safety" switches or settings which might be on so that children can't open doors or whatever.
Then if it is not operating as it should per the instructions, then you would need a factory service manual set of books (4 books to complete set - order from dealer). Then follow the troubleshooting instructions.
Many newer cars have computer modules in each door and signals to open/close locks would go over a computer network to those modules. Or it could be an old fashioned wired system. In either case, you would need the wiring diagrams and troubleshooting instructions to find the problem.
Billy_Bob is offline   Reply With Quote
Old 02-02-2012, 08:48 AM   #4
old guy contractor
tcleve4911's Avatar
Yes
They both work perfectly
The rear doors and gate all work together or in my case....don't work at all
Old 02-02-2012, 04:16 PM   #5
Not sure if it's the same on 2003. My 1999 suburban has pins between the body and rear doors to transfer power instead of wires. They get corroded sand them and put a little grease on the contact points. Worth a try lock actuators are common to go bad also.
cjm94 is online now   Reply With Quote
Receptacle stopped working lovetobuild Electrical 3 02-11-2011 11:05 AM
Some things not working on a circuit while others are? speedster1 Electrical 7 11-24-2010 07:23 AM
side by side light swithes not working katkell2645 Electrical 2 10-17-2008 08:22 PM
Two switch in one box: only one working jdtsmith Electrical 12 09-29-2008 02:32 PM
Furnace stops working once a day - help Da_Bears HVAC 2 01-26-2006 02:19 PM
