Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 12-30-2012, 05:27 PM   #1
Pro Flooring Installer
rusty baker's Avatar
Automatic door lock
2006 Dodge Caravan, one of the automatic door locks on a sliding door doesn't work. Is there a separate fuse or do you think it would be an actuator?
"I'm twisted, not sick. Sick implies, I'll get better"
Semi-Retired Installer
Installing since 1973
Old 12-30-2012, 06:48 PM   #2
Automatic door lock
They are on the same fuse make sure the contact point on the sliding door are clean. Most likely an actuator. Just two wires power and ground remove the panel then with the door shut have someone run the door switch while you use a test light
cjm94 is offline   Reply With Quote
Old 12-31-2012, 12:26 PM   #3
Automatic door lock
Sometimes vehicles have "known" problems with certain things. With that said, search google.com for the following words and read through some of the posts...
2006 caravan sliding door lock
Billy_Bob is offline   Reply With Quote
Old 01-01-2013, 03:04 PM   #4
Automatic door lock
Put your ear up to the door panel and hit the power lock button, normally if an actuator goes out it will still try to move and make a click noise. If you can her it, its just worn out and needs replaced.
D-rock is offline   Reply With Quote
Old 01-01-2013, 05:22 PM   #5
Automatic door lock
Where is the contact point?
Old 01-01-2013, 05:24 PM   #6
Automatic door lock
Thank you. Very low mileage, but there is a history on Caravans of door lock problems.
Old 01-01-2013, 05:52 PM   #7
Automatic door lock
Should be on the door jam. I mostly work on fords it's been awhile since I've seen a caravan. Most contact points are copper tabs on the body side and spring loaded buttons on the door. Make sure they are clean of corrosion.
The Following User Says Thank You to cjm94 For This Useful Post:
rusty baker (01-01-2013)
Old 01-07-2013, 09:45 PM   #8
Automatic door lock
You need a door lock actuator. I work at a dodge dealership and we replace them all the time for that issue. I do not think you will find that actuator aftermarket at like autozone or advance. I am pretty sure it will be dealer only.
streetneons is offline   Reply With Quote
Old 01-07-2013, 10:07 PM   #9
Automatic door lock
Autozone has it. I have already looked.
Automatic swing door opener subati Windows and Doors 1 09-13-2012 09:37 AM
Automatic Garage Door Issues sobro Windows and Doors 4 08-02-2012 11:11 PM
automatic gable shutter mammaw810 Building & Construction 1 04-25-2012 10:05 PM
main burners cut out/ no automatic vent damper? Shevek HVAC 6 11-14-2011 01:33 AM
Whole house automatic transfer switch? TronCarter Electrical 27 03-19-2008 09:39 PM
