#1 |
Audio *ding* with break peddle push
A rare problem in the recent past. Every time I press down the break peddle an audible ding would sound such as your reminder *ding to put on your seat belt. This occurred for about an hour and went away. I have not had the problem since but have always wondered where such a problem might stem from. I know it will start up again as soon as my warranty runs out.
2007 Dodge Ram 1500 SXT 2WD |
#2 |
Man of many hats
Funny you should ask. I just had the same thing happen 2 days ago on my Dodge Ram. It would also happen when I used my left turn indicator or brake, so I checked the left rear brake lamp and it was out. Since yours went away, I would suspect that maybe either a line short or a lamp that is loose or getting ready to go? As you said, it would be one ding with no fault indicator on the dash panel.
Man of many hats |
#3 |
I would agree that you probably have a loose brake lamp bulb filiment or loose connection in the bulb socket. I have seen this cause turn signal indicators to light up as well..
#4 |
Thanks Guys!
#5 |
Its all in the computer! I had some weird things happen with my Dodge Caravan (2005).
It was repaired by installing a patch into the computer. The dealer had the equipment, but it cost me $50 for the labor. While on this subject, on my 2002 F250,the cruise wouldn't work if the low fuel warning light came on. Is this a computer fault, or is it by design. |
#6 |
A common problem with the brake lights is not only the bulb but also the the circuit board/socket that the bulb plugs into. I have replace many. If it's not a "lamp out" issue, definately sound like a computer issue. The body computer in that vehicle is the instrument cluster. Also, is there a plow on the truck? Plow wiring can cause an issue with the lamp out system.
| Display Modes | |
| had to break down a door, how to repair splintered wood around lock area? | mxyplizk | Carpentry | 17 | 06-09-2009 09:42 AM |
| What do you think of the push in connectors? | jamiedolan | Electrical | 30 | 11-16-2008 03:13 PM |
| Delay on Break timers | rjbaiad | HVAC | 6 | 09-24-2008 06:17 AM |
| Checking audio cable for short? | mikehende | Electrical | 3 | 03-24-2008 03:32 PM |
| Just can't break sink drain free! | DIYtestdummy | Plumbing | 6 | 03-05-2008 10:56 AM |
