Attaching Floor Boards For Trailer... - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 02-15-2013, 02:03 PM   #1
Attaching floor boards for trailer...
I was given a flat bed trailer constructed of square tubing. It was some type of kayak trailer and never had a floor on it. I'm looking for some suggestions as to how to attach 2 x ? floor boards. I'll get a pic posted up soon. Thanks.
MisterSteve is offline   Reply With Quote
Old 02-15-2013, 02:33 PM   #2
Trailer
Old 02-15-2013, 02:51 PM   #3
Rewards Points: 390
Find a stock trailer to look at and see how they are done. That would be easier than me trying to explain it and MUCH easier for you to understand than me attempting to explain. Don't be surprised if you see the floor boards floating rather than fastened.
Old 02-15-2013, 02:56 PM   #4
Master General ReEngineer
Bondo's Avatar
Rewards Points: 334
Ayuh,.... What have ya got to work with,..??
Ya could weld brackets onto the bottoms of the tubin', 'n screw yer 2xs into the holes, 'tween the tubin'...
Or,...
You could just screw the 2xs right on top of the framin' there now....
Without some cuttin' grindin', 'n weldin', the 2nd option is probably yer Only choice...
Bondo is online now   Reply With Quote
Old 02-15-2013, 03:00 PM   #5
Concrete & Masonry
Rewards Points: 470
Our equipment trailer has screws similar to these http://www.mcfeelys.com/product/1220...d-Square-Drive that hold down 2" hardwood boards without any issues.................
jomama45 is online now   Reply With Quote
Old 02-15-2013, 03:05 PM   #6
Rewards Points: 320
Why do you want to use 2x's for the floor? Just use 3/4 inch exterior grade plywood. I have a similar trailer that folds up (4x8 ft). It had holes in the frame to bolt the plywood down. Drill holes through the frame if it doesn't already have them and use either stainless or galvanized stove bolts to fasten down the plywood.
teamo is offline   Reply With Quote
Old 02-15-2013, 03:36 PM   #7
I was thinking self tapping screws or carriage bolts but wasnt sure if drilling holes through the tubing with carriage bolts would compromise the strength at all or if the screws would really hold it all down well enough. The trailer is 5 1/2 x 9 so the ply wood sheets would almost cost as much as 2x's and same thing with the deck boards.
Old 02-15-2013, 03:38 PM   #8
Jomama, about how many screws are used on the boards? Two every cross member??
Old 02-15-2013, 03:41 PM   #9
Newbie Bill
Rewards Points: 518
That would be a concern for me as well.
Bill
A DIY Noob that knows just enough to be dangerous.
drtbk4ever is online now   Reply With Quote
Old 02-15-2013, 05:33 PM   #10
Rewards Points: 12,802
Ever once seen a factory build equipment trailer with a plywood floor, not likly.
Want it to last then use pressure treated decking boards. Through bolting with carrage bolts will work best.
Attaching porch railing to brick wiz561 Building & Construction 0 06-19-2011 02:39 PM
Attaching Cabinetry to Concrete Floor bchcadmin Remodeling 2 03-30-2010 07:21 PM
Garage storage, attaching to engineered beams jdcook72 General DIY Discussions 6 06-17-2009 12:01 AM
Attaching Drywall to 4" of Rigid Foam PerpetuallyRepairing Drywall & Plaster 9 02-19-2009 06:24 PM
Attaching Studs to Concrete/Which way mjkpainting Carpentry 17 12-30-2008 11:02 AM
