Anybody Know What This Hose Is For? - Automotive Repairs - Page 2 - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 11-18-2012, 10:17 AM   #16
Rewards Points: 254
They always paint them so they look pretty and justify the high price
cjm94 is offline   Reply With Quote
Old 11-18-2012, 10:18 AM   #17
Rewards Points: 254
Can be a little messy if you are quick with the new hose you won't lose much
The Following User Says Thank You to cjm94 For This Useful Post:
noquacks (11-18-2012)
Old 11-18-2012, 10:32 AM   #18
Rewards Points: 142
if it is rebuilt, they just painted it. but it is possible that the original case was bad, and they replaced it. either way, they paint em.
who cares if it is original, as long as it works well.
don't worry about loosing fluid. just put some cardboard on the floor. change hose, clean. check fluid level.
Fix'n it is offline   Reply With Quote
The Following User Says Thank You to Fix'n it For This Useful Post:
Old 11-18-2012, 10:34 AM   #19
Rewards Points: 142
Originally Posted by noquacks View Post
Oh- this "tranny cooler", where is it? Looks like to me it goes into the radiator, but I know it cant be.
well, yes, it does go to the radiator. they all do.
Old 11-18-2012, 11:42 AM   #20
Rewards Points: 252
Oh- this "tranny cooler", where is it? Looks like to me it goes into the radiator, but I know it cant be. Is this cooler soooo small? In front or back of rad? (also, theres the condenser to consider...)
The oil cooler is part of the radiator, usually at the very bottom. Many aftermarket radiators are made for the automatic and have the radiator cooler built in. If you have a manual, you just don't hook anything to it.
If you replace the hose, then make sure to get oil rated hose. Gates makes it as do many other mfg's. Hopefully, your hose isn't crimped on one end as an assembly and can be replaced easily.
It can be messy to deal with as well. I use a clamp on the hose if I am replacing it and put a pan under the radiator to catch what comes out of it as well. I pre-cut the hose to the right size first. Then, I usually remove the clamp and cut the line along the hose extending from the radiator with a razor knife. That allows me to bend the hose and it will release from the connecting tube. Do the same on the other end and then put on the new line with clamps and tighten. You shouldn't lose too much tranny fluid, but check the level and refill if necessary.
Marty1Mc is offline   Reply With Quote
The Following User Says Thank You to Marty1Mc For This Useful Post:
Old 11-18-2012, 03:44 PM   #21
Rewards Points: 1,062
Big thanks, for all the info! Now I get it!
Alexander Pope: [a little knowledge can be a dangerous thing]
noquacks is offline   Reply With Quote
Old 11-18-2012, 06:28 PM   #22
ukrkoz's Avatar
Rewards Points: 932
if it come out of trannie, then it's trannie cooler lines. Cooler radiator is normally built into the regular radiator, piggy backing it. Like someone already said.
ukrkoz is offline   Reply With Quote
The Following User Says Thank You to ukrkoz For This Useful Post:
noquacks (11-19-2012)
Old 11-18-2012, 07:41 PM   #23
Rewards Points: 12,856
I'm seeing one loose clamp and one that's not even where it belongs before it get tightened.
Old 11-19-2012, 06:19 PM   #24
You mean the hose should be over that "bead"before being tightened? I figured that too, but I dunno. I did tighten both of them and noticed the bad leaky one was the worst (way looser). Right now, Im trying it out- driving it for a bit to see if it still leaks. I'll let yous know.
Old 11-19-2012, 10:26 PM   #25
Rewards Points: 142
there "should" be another barb/s under the hose.
if the hose got looser after tightening it, you need a new hose and clamp.
don't let that leak burn up your trans. fix it now !
Old 11-20-2012, 06:50 PM   #26
LOL!! Dont worry, ol bud. I wont burn up that tranny. Just paid $1500 for rebuild.......
Repairing Garden Hose Connection cl6120 Plumbing 9 09-12-2012 10:20 AM
Sprayer hose removal zubby01 Plumbing 0 07-29-2011 01:51 PM
running extension from outside garden hose faucet denemante Plumbing 6 05-27-2011 01:18 PM
Simple hose connection? BataviaJim Plumbing 6 03-25-2010 01:52 PM
garden hose water spillage questions mcvane Landscaping & Lawn Care 10 07-29-2007 01:27 AM
