-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   Anti-Freeze (http://www.diychatroom.com/f46/anti-freeze-170793/)
gma2rjc 02-01-2013 11:46 PM
Anti-Freeze
Does anti-freeze (in a bottle/jug) last indefinitely? I found 3 partial gallons of it in the basement today and wonder if they can still be used or not.
One or two of them may be over 5 years old.
Thanks!
Barb
paintdrying 02-02-2013 01:03 AM
Not really sure. I have a few cases of oil in my garage that are over 20 years old. I have been using them with no problem. I can not even give it away to my friends. Everyone says the same thing, it is just not worth the chance. As for your antifreeze, what i will tell you is to have your anti frezze completely flushed and replaced with a good brand. I would rather not start any sort of debate by mentioning the word dexicool. However I will say some formulas in the past have had problems and have now been reformulated. I would properly recycle that antifreeze. I do not think it would cause you any problem but I would just go buy a good brand, it is not worth the chance
gregzoll 02-02-2013 01:40 AM
Not really. The more modern stuff. like GM's Dex Cool will have a longer lifespan, than older styles of Glycol. Most modern glycol's are made of a Sugar base, whether it is Corn, or some type of natural sugar, unlike the older green stuff. The joke always was, when we would de-ice planes, that if you swallowed some, you can take a good swig of Vodka, and be fine.
Keep in mind, that Polypropylene glycol is used for Constipation, and as a food additive, and medicine additive, whether it is in a powdered or liquid form. But on the other hand, Ethylene glycol is dangerous, due to it not only attacks the central nervous system, but also causes renal failure.
gma2rjc 02-02-2013 12:15 PM
Thanks guys. I'll take it to the recycling station.
johnniebravo 02-08-2013 05:31 PM
I know this is already answered but just add two comments, the additives in the older antifreeze/coolant may not be necessarily compatible with your current cooling system. As an example, some newer cars recommend to use phosphate antifreeze. Lastly, the fluid is also used to lubricate the water pump, old fluid may lack the necessary additives (from age) to properly keep the pump going long term.
gma2rjc 02-08-2013 07:24 PM
Thanks jonniebravo.
7wUPEYpAVU 02-12-2013 11:20 AM
There is a cheap tester you can buy to determine if it is still good. It probably is.
http://www.autozone.com/autozone/acc...er=525881_0_0_
I use one to determine when my cars really need a coolant flush.
gregzoll 02-12-2013 12:26 PM
We would actually cheat, and use the Recractometer that we used for de-icing fluid freeze levels at the Regional air carrier that I worked for one time, to check the proper levels of our car's & equipment anti-freeze. http://www.amazon.com/RHA-100ATC-Eth...+glycol+tester
BigJim 02-12-2013 01:09 PM
Might want to check the label when buying antifreeze, here the 50/50 costs $10.95 and the straight antifreeze costs $12.95, that means you are paying $4.47 for a half gallon of water if you buy the 50/50 mix. Just a thought.
gregzoll 02-12-2013 01:33 PM
Jim your math is off. You would be paying $2.95 more for non-diluted anti-freeze, over the 50/50 The reason for the 50/50, is because people were it takes out having people possibly contaminate the Anti-Freeze with bad water, or end up pouring straight solution into the radiator.
Bondo 02-12-2013 02:00 PM
Ayuh,... Jim's math is Right, as is yer's, just different angles...
I disagree with yer assumptions on the Why's of sellin' diluted antifreeze...
If it were for Convenience, it would be better stated on the label,...
rather than hidin' it in the same jug, with nearly the same label, 'n only a tiny statement that it's diluted...
I see it as a marketin' ploy to sell Water, at antifreeze prices....
'n as for the main topic,... No, antifreeze does Not go Bad, sittin' in it's jug on a shelf,...
gregzoll 02-12-2013 02:30 PM
Actually it will Bondo. There is a reason why airlines have to test the De-Icing solution daily, and when delivered, or before Winter de-icing season starts. Any solution when left sitting, will separate and go bad, so that is why you should never keep on hand anything that you cannot use within a certain period of time.
Bondo 02-12-2013 04:11 PM
Ayuh,... Not doubtin' yer word Greg,...
Sealed in the jug is alittle hard to believe goes Bad,...
'n I've seen it in a ole junk car radiators, 20 years old, 'n it still don't freeze...
Just to be clear, I'm talkin' the good ole green fluid I've been dumpin' into radiators since the 60s...
I know it changes with use, 'n the additives either need to be renewed, or the antifreeze replaced in time, Especially in Diesels...
I've got the Test kit for 'em, 'n manage a small fleet of dumptrucks, 'n equipment...
I do a dump, 'n fill on the fleet every few years,...
'ell,... The dumped fluid, I use as a wood preservative to kill wood rot...
As to Barb's original post question,...
I wouldn't hesitate for an Instant, 'n I'd use those jugs found in the garage...
polarzak 02-12-2013 05:46 PM
I would agree. My new 2000 GM went for trade in 07 with the same antifreeze in it when I drove off the the lot in 99. Almost 350k on it and the last winter I had it saw 15 to 20 below. It was still clean.
paintdrying 02-12-2013 10:09 PM
Oh Crap, I hope i am not getting sucked into another anti freeze debate. Extended life anti freeze is fine, just change it every other year. Never mix ant freeze types. There is more to an anti freeze than if it freezes or not. Just ask Cadillac. The chemistry behind anti freeze has changed a lot in five years. Best thing to do is EVERY year change your anti freeze and thermo stat. Completely flushing it. And that 50/50 is a rip off.
