Ambient Air Temp In 97 Silhouette - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 03-13-2014, 06:11 PM   #1
Rewards Points: 562
ambient air temp in 97 silhouette
Have a 97 Olds Silhouette that I just changed the battery a few months ago which caused the ambient temp sensor not to work on the display on the above panel.
It reads OC. I tried everything I knew to try. Changed sensor by grille. Unplugged it for a few days,,,nothing helped. Even took it to dealer with no help.
ANY suggestions on getting this to work??? It is not good to let it not work as something I read says it can adversely affect you mileage
4just1don is offline   Reply With Quote
Old 03-13-2014, 08:13 PM   #2
Rewards Points: 268
In my experience, when it reads 'OC' it is telling you that the two wire circuit to the exterior temp sensor is 'open circuit' (infinite resistance). Either one -or both- of the wires is open somewhere between the display head and the temp sensor, or the sensor itself is open. Or, less common, a solder joint opened up on the circuit board in the display.
And no, it will not affect your mileage. The Engine Coolant Temperature sensor will, as will the Intake Air Temperature sensor, but not the ambient temp sensor.
Marqed97 is offline   Reply With Quote
hi temp boiler cutoff jmon HVAC 20 12-05-2012 08:01 PM
Peerless oil furnace - keeps turning on when temp exceeds target temp eugenet1979 HVAC 0 12-22-2011 08:30 PM
outdoor hot tub won't heat to temp but hold a steady temp PiPiFirecracker Electrical 11 11-24-2011 07:42 PM
boiler temp overshoot johnnyzero HVAC 0 11-08-2011 09:52 AM
AC Temp drop over plenum run length BlueBSH HVAC 23 06-22-2010 08:10 AM
