Also. I Have A Strong Smell Of Anti Freeze When I Start My Gran Marquis - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 11-03-2010, 07:16 PM   #1
bsa_bob
Rewards Points: 150
Unhappy
also. i have a strong smell of anti freeze when i start my gran marquis
I have a 97 with 73,000 miles on it. Well taken care of,but this strong smell..it goes away after you drive it awhile.Nothing leaking on the floor, or the engine, And the coolant never need any added. after the oil is changed. The w/s is clear nothin blowing up on it.
A heater core leak, would show up after a compression test wouldn't it.
Would it make the leak or smell worse with this test? anything this car is startin to give me headaches bob s thank you for anything
bsa_bob is offline   Reply With Quote
Old 11-04-2010, 12:04 PM   #2
Rewards Points: 150
I would guess either heater core, or some valve/hose in the heater system. That is about the only way you end up with the odor in the car.
240sx4u is offline   Reply With Quote
Old 11-04-2010, 01:34 PM   #3
bsa_bob
Rewards Points: 150
Thank you 240sx4u bob s
Old 11-06-2010, 05:30 PM   #4
Rewards Points: 18
heater core may be leaking and dripping antifreeze out of the ac drip tube on the firewall.
lorel is offline   Reply With Quote
Old 11-06-2010, 06:22 PM   #5
bsa_bob
Rewards Points: 150
I had the oil changed ths week....and told the attendant,,,,to check for any drips underside of the car, he came up empty! nothin dripping anywhere, shes in the garage till nex summer now , so-i can wait til then til i figure it out ...but thanks all for the input cheers all bob s
Old 11-07-2010, 01:41 PM   #6
Rewards Points: 18
take it to a shop then pressure check it
I have a new kit that can do all cars. It will show just like my old stant if you have a leak and where it is coming from. Now, if its really difficult to locate, this is a interesting way of finding it. If the shop has a smoker used to detect vacuum leaks, ask if it can be adapted to the cooling system. If so, shop will drain coolant, then air pressurize cooling system with the smoker "I do not think this has ever been done before" but you could ask. Then smoke will come out of area where it is leaking.
good luck.
Old 11-08-2010, 08:03 AM   #7
bsa_bob
Rewards Points: 150
[quote=lorel;530250]I have a new kit that can do all cars. It will show just like my old stant if you have a leak and where it is coming from. Now, if its really difficult to locate, this is a interesting way of finding it. If the shop has a smoker used to detect vacuum leaks, ask if it can be adapted to the cooling system. If so, shop will drain coolant, then air pressurize cooling system with the smoker "I do not think this has ever been done before" but you could ask. Then smoke will come out of area where it is leaking.
good luck.[/quote
Thats a new one!! i've never heard that before .but i will make note of it fpr the spring. thankyou YOU say this is a"kit"....... that you by???? bob s let mreknow where you got it.
Old 11-08-2010, 08:26 PM   #8
Rewards Points: 18
sorry if not clear
What I am saying is, I have a coolant pressure test kit. It will show a drop in the needle and also, where the antifreeze is leaking from. but why make a mess if its a difficult to find one? I wonder if a smoker has been used for something like this. It would be easier to see smoke rising from a engine compartment, then water dripping down the side of a engine then have to guess where its coming from
Old 11-08-2010, 10:10 PM   #9
DIY'er
Rewards Points: 35
Is the smell inside the car or outside the car? If its inside its more than likely the heater core.
dirtrider73068 is offline   Reply With Quote
Old 11-09-2010, 06:37 AM   #10
bsa_bob
Rewards Points: 150
inside!
Old 11-09-2010, 08:17 AM   #11
DIY'er
Rewards Points: 35
Then it could be the heater core, if its leaking in the passenger floor board you might be able to feel a wet spot or see it dripping out of the bottom of the dash. As it gets worse and does go it will get really steamy inside the care I had this happen one time.
Old 11-27-2010, 09:34 PM   #12
Rewards Points: 410
I had a 97 , my son has it now.
Normally smell inside is a heater core , but a very common issue with these is a
cracked intake manifold ( the coolant crossover cracks ( plastic intake ).
If that's the case go with the aftermarket Doreman intake as its a stronger design.
If your intake has never been replaced I'd bet dollars to donuts that's it.
High Gear is offline   Reply With Quote
Bad smell in crawl space. John_W General DIY Discussions 34 06-03-2014 01:57 PM
Smell when boiler runs? dave12345 HVAC 13 11-11-2013 09:08 AM
Drywall problems in new house BettyCv Building & Construction 39 05-28-2010 02:51 PM
strong smell of oil from oil burner room mayhem69 HVAC 3 05-13-2010 08:37 AM
Strong Mildew Smell - No Visible Source EvanJ Introductions 3 02-27-2009 11:21 AM
