Air Check Valve Location On 1991 Pontiac 6000? - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 04-14-2013, 11:48 AM   #1
Rewards Points: 33
Air Check Valve location on 1991 Pontiac 6000?
Good Morning!
I hope everybody is having a good weekend. I need to replace the vacuum air check valve on my 1991 pontiac 6000 LE, but haven't been able to locate the darn thing. The motor is the 3.1l v6. When I accelerate, especially uphill, I lose enough vacuum that my a/c controls switch back to defrost, so I'm pretty confident the check valve is the issue.
Here's the part:
This car is basically the same as the Chevrolet Celebrity, Buick Century, and Olds Cutlass Ciera from the same genre. I'm leaving on a trip this afternoon in this car, so any help locating this would be greatly appreciated.
Thanks!!
Patriot_RAM
Patriot_RAM is offline   Reply With Quote
Old 04-14-2013, 12:07 PM   #2
World's Tallest Midget
Mort's Avatar
Rewards Points: 690
Try following the vacuum line from the power brake booster. Should be somewhere on the intake manifold.
I hate signatures.
Mort is online now   Reply With Quote
Old 04-14-2013, 12:37 PM   #3
Rewards Points: 33
Thanks for the quick reply. That vacuum line does have a check valve on it where it connects to the brake booster. It's a smaller, 90 degree valve. I removed it and did a quick blow test and that one seems to work properly. The other end of that vacuum line connects directly to the intake near the top.
I still cannot locate the one in the photo above. I checked NAPA, O'Reilly, and Auto Zone part searches and 3 out of 3 of them indicated the part above is correct. Do you know where there might be another, larger check valve somewhere in the system?
Thanks!
Patriot_RAM
Husky/CH Compressor check valve question EdPDX Tools 7 10-02-2012 05:37 PM
How to check gas control valve? downunder HVAC 8 02-03-2009 08:48 PM
hot water check valve? Ultrarunner2017 Plumbing 7 01-30-2009 02:36 PM
check valve question burr HVAC 3 11-30-2008 11:03 AM
Sewage Lid + check valve majorchamp Plumbing 2 07-07-2008 11:06 AM
