-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   Air Check Valve location on 1991 Pontiac 6000? (http://www.diychatroom.com/f46/air-check-valve-location-1991-pontiac-6000-a-177121/)
Patriot_RAM 04-14-2013 10:48 AM
Good Morning!
I hope everybody is having a good weekend. I need to replace the vacuum air check valve on my 1991 pontiac 6000 LE, but haven't been able to locate the darn thing. The motor is the 3.1l v6. When I accelerate, especially uphill, I lose enough vacuum that my a/c controls switch back to defrost, so I'm pretty confident the check valve is the issue.
Here's the part: http://partimages.genpt.com/partimages/95160.jpg
This car is basically the same as the Chevrolet Celebrity, Buick Century, and Olds Cutlass Ciera from the same genre. I'm leaving on a trip this afternoon in this car, so any help locating this would be greatly appreciated.
Thanks!! :thumbsup:
Patriot_RAM
Mort 04-14-2013 11:07 AM
Try following the vacuum line from the power brake booster. Should be somewhere on the intake manifold.
Patriot_RAM 04-14-2013 11:37 AM
Thanks for the quick reply. That vacuum line does have a check valve on it where it connects to the brake booster. It's a smaller, 90 degree valve. I removed it and did a quick blow test and that one seems to work properly. The other end of that vacuum line connects directly to the intake near the top.
I still cannot locate the one in the photo above. I checked NAPA, O'Reilly, and Auto Zone part searches and 3 out of 3 of them indicated the part above is correct. Do you know where there might be another, larger check valve somewhere in the system?
Thanks!
Patriot_RAM
