Adhesive For Rubber To Metal - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 04-26-2011, 07:56 AM   #1
Rewards Points: 120
Adhesive for rubber to metal
My Toro mower has two rubber pads on which the carriage pins for the front of the deck rest, and after 15+ years of service, they are worn to the point that I am going to replace them. The pads are something like 1-1/2" x 3" x 1/4" thick rubber, with no place to bolt them, and obviosly subjected to a fair amount of viration. My thoughts are to check with my local parts store, to see what they have, perhaps a 3M or Loctite product, but wondered if anyone might have other thoughts or suggestions.
Old 04-26-2011, 09:07 AM   #2
fabrk8r
fabrk8r's Avatar
3-M Trim and Emblem adhesive should work. Available at auto parts stores or auto-body supply stores. It's very similar to the contact cement we use to adhere rubber armaflex insulation to metal duct which has to withstand both vibration and high velocity air.
Apply the adhesive to both the rubber and the metal and allow to tack before putting the pads in place.
"The physician can bury his mistakes, but the architect can only advise his clients to plant vines." -- Frank Lloyd Wright
fabrk8r is offline   Reply With Quote
Old 04-26-2011, 09:36 AM   #3
Rewards Points: 120
Thank you very much, Sir; that sounds exactly in line with what I was thinking, but wasn't sure of the specific product. My auto parts store handles body shop supplies as well, so it sounds like something that they should have on the shelf. Now, do you happen to know where I set that doggone piece of rubber that I was going to use for this?
Old 04-26-2011, 10:03 AM   #4
fabrk8r
fabrk8r's Avatar
If you're lucky like me it will be in the last place you look for it.
Don't forget to clean both the metal and the pads with denatured alcohol or mineral spirits before applying the adhesive!
Old 04-26-2011, 10:31 AM   #5
Pro Flooring Installer
rusty baker's Avatar
Rewards Points: 148
You'll find that when you come home after buying another piece.
The ads in my post are there without my permission. I do not endorse any of the products.
Semi-Retired Installer
Installing since 1973
Old 04-26-2011, 11:45 AM   #6
Rewards Points: 120
Yes, had planned to clean it properly first, but thank you for the reminder. I was debating about stopping by TSC or the hardware store this afternoon, to buy a piece of rubber, but know that if I do, I will walk in the barn and be looking right at it.
Old 04-27-2011, 08:50 AM   #7
Getting There
MecGen's Avatar
AAAArrrrggggg
That happens to me all the time, I just loose it
Frank
MecGen is offline   Reply With Quote
Why can't you connect Ground/Neutral bus bars on a sub secutanudu Electrical 42 11-07-2012 01:33 PM
Adhesive for Marble Threshold Twister Flooring 11 05-14-2011 01:20 PM
floating laminate over old adhesive jbitt Flooring 3 09-27-2010 04:58 PM
adhesive under metal on glass blaqpig General DIY Discussions 2 06-30-2009 11:07 AM
Wire size for 300watt trans, 3 way 100ft Al the Diy guy Electrical 16 03-22-2008 08:46 PM
