Go Back   DIY Chatroom - DIY Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 12-02-2011, 09:17 PM   #1
Adhesive for loose rubber around door
The rubber gasket(not sure if that is the right word) that goes around the passenger side door has become loose on the bottom.
I have ignored it for awhile and now it is so loose that when I close the door it partially hangs out.
I tried a thick black glue at the recommendation of someone, but no luck...
Do you have a recommended adhesive to attach the rubber to the steel of the door.
caseynshan is offline   Reply With Quote
Old 12-02-2011, 09:30 PM   #2
Are you talking about a gasket on a car door?
If so any auto parts store has the right adhesive for that. It may not work now that you have applyed something else unless you can get it all off and clean the area where it's going.
Old 12-02-2011, 10:25 PM   #3
ukrkoz's Avatar
called weather stripping and they do sell weather stripping adhesive in stores. but I have not seen them glued in doors in long time. they have built in clips system, or have plastic anchors holding them in place.
ukrkoz is offline   Reply With Quote
Old 12-02-2011, 11:28 PM   #4
Try E-6000 Industrial Adhesive. It holds in temperatures between -40º F and 150º F. Here is some info I found when I googled it.
  • Clear Multi-Purpose Adhesive
  • Self-Leveling Formula, Medium Viscosity
  • Abrasion resistant -- Flexible hold
  • Waterproof -- Paintable
  • Adheres to more surfaces than virtually any other adhesive: wood, metal, glass, fiberglass, ceramics, masonry, concrete, leather, rubber, vinyl, neoprene, many plastics.
  • This cement does NOT dry instantly -- you have at least 5 minutes to make adjustments before the glue starts to set. For maximum strength bond, allow 24-72 hours for complete curing.
  • Excess can be cleaned/removed from work-surfaces. Use sense when using adhesives - use in a well-ventilated area, remove excess from skin promptly, do not get any in your eyes, etc. etc.!
  • NOTE: This glue is not the same as an epoxy.
You can buy it on ebay or at craft and hobby stores - probably at HD, Lowe's, etc. too. I think I paid about $4.99 for a 3.7 oz. tube at Michael's, but it's not just for crafts.
"The problem with quotes on the Internet is that it is often difficult to verify their authenticity." - Abraham Lincoln
The economy is so bad, Exxon-Mobil laid-off 25 congressmen --- Maxine
gma2rjc is offline   Reply With Quote
Old 12-03-2011, 09:51 AM   #5
Thanks, yes, the little plastic pieces have broken off.
Can I shorten a Fiberglass door. rjniles Building & Construction 6 12-08-2010 01:57 PM
Help with Swing out door into Breezeway/garage Brick wall! wad2k Building & Construction 3 04-25-2010 06:45 PM
French Doors from Homedepot or Lowes??? johnnytuinals General Discussion 47 01-10-2009 11:00 PM
Possible foundation, door gap problems Jemo Building & Construction 1 02-11-2007 09:43 AM
