Adding Rear Blocks To A 05 Z71???? - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 02-22-2009, 12:02 AM   #1
Adding rear blocks to a 05 Z71????
I bought 2 rear 3 inch leaf spring blocks for my Z71 today. They are supposed to go between the leaf springs and axle. But, the Z71 came stock with a 2 inch block, and the instructions for the new ones say not to add it if the truck already has one. So do I just add the block anyways, on top of or under the stock one, or what?
truckobsession is offline   Reply With Quote
Old 02-22-2009, 12:12 AM   #2
You can stack the blocks but I personally dont like the idea and have seen poeple spit them out while offroad. I would either buy one large block or an ad a leaf. Both are cheap and would give you the same end results.
M. Ready is offline   Reply With Quote
Old 02-24-2009, 01:29 PM   #3
World's Tallest Midget
Mort's Avatar
Rewards Points: 690
I agree, never stack blocks. Its sorta like building stuff that isn't up to code. It can be done, it HAS been done, and you probably won't die, but its not a good idea.
You say Z71, is it a half-ton or 3/4-ton? If so, 1-ton blocks are usually larger (if my experience with Fords are of any use).
I hate signatures.
Mort is offline   Reply With Quote
Old 02-24-2009, 11:46 PM   #4
Rewards Points: 150
Try www.chevytalk.org They can tell you not to do it!
Gary
Gary_602z is offline   Reply With Quote
Old 02-26-2009, 02:34 AM   #5
This truck did not have a block in it from the factory, they must have been added in sometime.
Another vote here for not stacking 2 blocks, just get a bigger block for the height you want.
oregondiy is offline   Reply With Quote
Adding more weight to truss system... what can it hold? Sonnie Building & Construction 7 02-06-2009 09:45 PM
Framing in basement attached to concrete blocks, how to insulate? drnormie Remodeling 11 01-21-2009 06:40 PM
Adding new duct/Register CEbury HVAC 1 06-25-2008 11:51 AM
AAC or standard CMU blocks oar Building & Construction 3 06-10-2008 07:43 AM
Rear Window Seal Crista Automotive Repairs 2 11-18-2007 11:16 AM
