Ac On Blazer - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 06-30-2013, 12:34 PM   #1
Rewards Points: 164
Ac on blazer
Have a big problem, I am changing my accumulator to my ac unit and the back line is frozen on there, I have been at this for an hour and even brought it to a mechanic and still nothing help!!!!! Any tricks, it's the back line going into fire wall I don't want to break it...
bostonwindows30 is offline   Reply With Quote
Old 06-30-2013, 03:34 PM   #2
Bigplanz's Avatar
Rewards Points: 990
Cut it out and replace them both. Even if you get it off it won't seal right when you put the new accumulator.
Bigplanz is offline   Reply With Quote
Old 06-30-2013, 03:39 PM   #3
ukrkoz's Avatar
Rewards Points: 954
Frozen as in? Not sure about GMs, but Fords have special quick disconnect couplings and require special tool to disconnect them.
Looked at my Silverado book, as they should be quite similar in design. Looks like it's simple nut that holds line via flange, right? And line has O-ring inside of it. Si it's "frozen" at the O-ring likely? Lots of penetrating oil, I should say, and let it soak. Lines are aluminum, apply no force to them.
ukrkoz is offline   Reply With Quote
Old 06-30-2013, 03:42 PM   #4
ukrkoz's Avatar
Rewards Points: 954
Hey, Big, you know what it'll take to replace lines that go through firewall?
Old 06-30-2013, 05:46 PM   #5
Rewards Points: 164
I ended up replacing the vaporator it was 100 bucks but damn I couldn't get it off, lol I see metal and aluminum doesn't and shouldn't be together I think after time they locked together with heat but I got it and replaced both, thanks guys...
Old 06-30-2013, 06:27 PM   #6
ukrkoz's Avatar
Rewards Points: 954
Yeah, unfortunately, any non aluminum metal creates so called bi-metallic pair with aluminum. As a result, you have galvanic currents running between the two, accelerating oxidizing process. In addition, if a/c is not run on a regular basis, it gums up from the freon, and guess where it gums the most - elbows and joints.
Old 06-30-2013, 06:38 PM   #7
Rewards Points: 164
Very true, kinda sucks on the extra cost but It done, now I have alot of new parts lol
Torch Down Instructions Needed - DIY MikeinBurien Roofing/Siding 86 10-07-2012 11:21 AM
90 chevy blazer darney Automotive Repairs 4 07-23-2009 10:34 PM
2004 S10 Blazer gas tank joeyuk Automotive Repairs 5 06-13-2008 09:41 AM
