Abs Pump 2003 Windstar ??? - Automotive Repairs - DIY Chatroom Home Improvement Forum
Go Back   DIY Chatroom Home Improvement Forum > Do It Yourself > Automotive Repairs
Old 08-31-2011, 10:30 PM   #1
abs pump 2003 Windstar ???
Hi - 2003 Ford Windstar 85K, traction control light and check engine light comes on when you accelerate then stays on. Abs pump with computer replacement is what the ford dealer says $1500 + labor...ouch. Are there any other checks that I could do to confirm that replacement is not the only option - Thanks in advance.
wendl is offline   Reply With Quote
Old 09-01-2011, 12:47 AM   #2
Rewards Points: 150
I'm, not totally familiar with that unit but if the dealer said it has their hydroboost system on it for the ABS, it's expensive. You might call around and see if you can find a rebuilt unit. The hydroboost is a separate unit from the power booster FWIW. If you look under the hood, you'll see the power booster on the firewall. Follow the 2 brake lines to another unit where 4 brakes lines come out. There's yer hydroboost. They can be a real pain to work on so this is not a DIY project unless you have access to a power bleeder and lots of DOT3 fluid.
TrapperL is offline   Reply With Quote
Sump Pump Questions henlij Plumbing 22 03-16-2015 11:00 PM
Sump pump jerks when it turns on Sparkastic Plumbing 3 08-25-2011 07:51 PM
Sump pump operation MikeKy55 Plumbing 16 05-11-2011 05:35 PM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 07:10 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
