-   Automotive Repairs (http://www.diychatroom.com/f46/)
-   -   abs pump 2003 Windstar ??? (http://www.diychatroom.com/f46/abs-pump-2003-windstar-115895/)
wendl 08-31-2011 09:30 PM
Hi - 2003 Ford Windstar 85K, traction control light and check engine light comes on when you accelerate then stays on. Abs pump with computer replacement is what the ford dealer says $1500 + labor...ouch. Are there any other checks that I could do to confirm that replacement is not the only option - Thanks in advance.
TrapperL 08-31-2011 11:47 PM
I'm, not totally familiar with that unit but if the dealer said it has their hydroboost system on it for the ABS, it's expensive. You might call around and see if you can find a rebuilt unit. The hydroboost is a separate unit from the power booster FWIW. If you look under the hood, you'll see the power booster on the firewall. Follow the 2 brake lines to another unit where 4 brakes lines come out. There's yer hydroboost. They can be a real pain to work on so this is not a DIY project unless you have access to a power bleeder and lots of DOT3 fluid.
